Acer Aspire 3 A315-58-350L Screen Replacement
  1. Acer Aspire 3 A315-58-350L Screen Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-58-350L Screen Replacement, Lower Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eleven 7 mm Phillips screws that secure the lower case.
  2. Acer Aspire 3 A315-58-350L Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-58-350L Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-58-350L Screen Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry along the perimeter until the lower case releases.
    • Lift off the lower case.
  3. Acer Aspire 3 A315-58-350L Screen Replacement, Wi-Fi Card: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-58-350L Screen Replacement, Wi-Fi Card: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-58-350L Screen Replacement, Wi-Fi Card: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening tool to lift and disconnect the Wi-Fi card antenna cables.
    • Remove the single 2 mm Phillips screw that secures the Wi-Fi card.
    • Pull the Wi-Fi card directly out of its socket.
  4. Acer Aspire 3 A315-58-350L Screen Replacement, Screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-58-350L Screen Replacement, Screen: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six 4 mm Phillips screws that secure the hinges.
    • There are three screws securing each bracket.
  5. Acer Aspire 3 A315-58-350L Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-58-350L Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to grab both ends of the display connector.
    • Pull the connector directly out of its socket.
  6. Acer Aspire 3 A315-58-350L Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-58-350L Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-58-350L Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the laptop and gently separate the display assembly from the lower chassis.
  7. Acer Aspire 3 A315-58-350L Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-58-350L Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-58-350L Screen Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening tool between the bezel and display
    • Pry around the entire perimeter of the screen until the bezel releases.
    • Pull the bezel away from the hinges to remove it.
  8. Acer Aspire 3 A315-58-350L Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-58-350L Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-58-350L Screen Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six 3 mm Phillips screws that secure the two hinges.
    • There are three screws that secure each hinge.
  9. Acer Aspire 3 A315-58-350L Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-58-350L Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-58-350L Screen Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 3 mm Phillips screws on the bottom left and right corner of the screen.
    • Use an opening tool to separate the display from the display assembly.
  10. Acer Aspire 3 A315-58-350L Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-58-350L Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-58-350L Screen Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tweezers to lift brass display connector hinge.
    • Pull the display connector directly out of its socket.
    • Remove the display.
Evan Sandoval
crwdns2935283:009/11/23crwdne2935283:0
879 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 9-1, Watkins Spring 2024 crwdns2935289:0Austin Community College, Team 9-1, Watkins Spring 2024crwdne2935289:0
AUSTINCC-WATKINS-S24S9G1
crwdns2935297:011crwdne2935297:0
Hi Evan,
Thanks for the walkthrough, I was able to get the screen replaced. I did want to call out Step 4 as a tripping point for me. Since you disassembled or....shopped the image (for ease of display I'm sure) the mainboard monitor hinge screws in the image show all three screws in place with the case removed.
The screw holes with the large X in your images are actually two of the exterior case screws. so showing them in place without the case on made me search for two missing screws for about an hour. Not complaining but I wanted to help anyone else who might get caught on that part.
Jim Anderson - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 540
