Acer Aspire 3 A315-24PT-R288 Screen Replacement
  1. Acer Aspire 3 A315-24PT-R288 Screen Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24PT-R288 Screen Replacement, Lower Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • For your safety, unplug all peripheries, discharge the battery below 25%, and power down your device before beginning disassembly.
    • Use a Phillips screwdriver to remove the eleven 2 mm screws that secure the lower case.
  2. Acer Aspire 3 A315-24PT-R288 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert an opening pick in the seam between the chassis and the lower case.
    • Slide the opening pick around the entire perimeter, prying every couple of centimeters, to release all of the retaining clips that secure the lower case.
    • Remove the lower case.
  3. Acer Aspire 3 A315-24PT-R288 Screen Replacement, Acer Aspire 3 A315-24PT-R288 Battery Disconnection: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the tape on the battery connector using tweezers or your fingers.
  4. Acer Aspire 3 A315-24PT-R288 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24PT-R288 Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening pick or the flat end of a spudger to gently push the battery connector out of its motherboard socket.
  5. Acer Aspire 3 A315-24PT-R288 Screen Replacement, Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop over and open the lid.
    • Insert an opening pick in the seam between the bezel and screen.
    • Pry around the entire perimeter of the bezel to release the clips.
    • Remove the bezel.
  6. Acer Aspire 3 A315-24PT-R288 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove both of the 2 mm screws at the top-left and top-right corners of the screen.
  7. Acer Aspire 3 A315-24PT-R288 Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eight 3 mm screws that secure the hinge to the display assembly.
    • There are four screws on each hinge.
  8. Acer Aspire 3 A315-24PT-R288 Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the small press connector on the top-left side of the screen.
  9. Acer Aspire 3 A315-24PT-R288 Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Dislodge the cords from their retaining hooks.
  10. Acer Aspire 3 A315-24PT-R288 Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the screen away from the display assembly, with care not to strain the connected cables.
  11. Acer Aspire 3 A315-24PT-R288 Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24PT-R288 Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay down the screen flat with the back facing you.
    • Flip up the display connector locking bar.
    • Pull the display connector directly out of its socket.
    • Remove the screen.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Zachariah Fernandez
crwdns2935283:002/19/25crwdne2935283:0
316 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 17-5, Thornton Spring 2025 crwdns2935289:0Sam Houston State, Team 17-5, Thornton Spring 2025crwdne2935289:0
SHSU-THORNTON-S25S17G5
crwdns2936753:030crwdne2936753:0 54
crwdns2942667:0crwdne2942667:0 213
