Acer Aspire 3 A315-24PT-R288 Heat Sink Replacement
  1. Acer Aspire 3 A315-24PT-R288 Heat Sink Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24PT-R288 Heat Sink Replacement, Lower Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • For your safety, unplug all peripheries, discharge the battery below 25%, and power down your device before beginning disassembly.
    • Use a Phillips screwdriver to remove the eleven 2 mm screws that secure the lower case.
  2. Acer Aspire 3 A315-24PT-R288 Heat Sink Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert an opening pick in the seam between the chassis and the lower case.
    • Slide the opening pick around the entire perimeter, prying every couple of centimeters, to release all of the retaining clips that secure the lower case.
    • Remove the lower case.
  3. Acer Aspire 3 A315-24PT-R288 Heat Sink Replacement, Acer Aspire 3 A315-24PT-R288 Battery Disconnection: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the tape on the battery connector using tweezers or your fingers.
  4. Acer Aspire 3 A315-24PT-R288 Heat Sink Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24PT-R288 Heat Sink Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening pick or the flat end of a spudger to gently push the battery connector out of its motherboard socket.
  5. Acer Aspire 3 A315-24PT-R288 Heat Sink Replacement, Heat Sink: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24PT-R288 Heat Sink Replacement, Heat Sink: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24PT-R288 Heat Sink Replacement, Heat Sink: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Despite the images, it's not necessary to remove the fan prior to removing the heat sink.
    • Remove the three 2mm Phillips #1 screws from the heat sink.
    • When installing your new heat sink, be sure to fasten the screws in the numerical order stamped on the heatsink bracket.
  6. Acer Aspire 3 A315-24PT-R288 Heat Sink Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24PT-R288 Heat Sink Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the heat sink up and out of the chassis.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Monique
crwdns2935283:002/19/25crwdne2935283:0
361 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 17-5, Thornton Spring 2025 crwdns2935289:0Sam Houston State, Team 17-5, Thornton Spring 2025crwdne2935289:0
SHSU-THORNTON-S25S17G5
crwdns2942667:0crwdne2942667:0 60
