Acer Aspire 3 A315-24PT-R288 Battery Replacement
  1. Acer Aspire 3 A315-24PT-R288 Battery Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24PT-R288 Battery Replacement, Lower Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • For your safety, unplug all peripheries, discharge the battery below 25%, and power down your device before beginning disassembly.
    • Use a Phillips screwdriver to remove the eleven 2 mm screws that secure the lower case.
  2. Acer Aspire 3 A315-24PT-R288 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert an opening pick in the seam between the chassis and the lower case.
    • Slide the opening pick around the entire perimeter, prying every couple of centimeters, to release all of the retaining clips that secure the lower case.
    • Remove the lower case.
  3. Acer Aspire 3 A315-24PT-R288 Battery Replacement, Acer Aspire 3 A315-24PT-R288 Battery Disconnection: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the tape on the battery connector using tweezers or your fingers.
  4. Acer Aspire 3 A315-24PT-R288 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24PT-R288 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening pick or the flat end of a spudger to gently push the battery connector out of its motherboard socket.
  5. Acer Aspire 3 A315-24PT-R288 Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4 mm Phillips screws that secure the battery.
  6. Acer Aspire 3 A315-24PT-R288 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery up and out of the chassis.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Kelaia Delgado
crwdns2935283:002/19/25crwdne2935283:0
217 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 17-5, Thornton Spring 2025 crwdns2935289:0Sam Houston State, Team 17-5, Thornton Spring 2025crwdne2935289:0
SHSU-THORNTON-S25S17G5
crwdns2942667:0crwdne2942667:0 261
