Acer Aspire 3 A315-24P-R7VH SSD Replacement
  1. Acer Aspire 3 A315-24P-R7VH SSD Replacement, Power off your laptop: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Shut down your laptop and unplug any cables.
  2. Acer Aspire 3 A315-24P-R7VH SSD Replacement, Remove the back cover screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Close the laptop and flip it over on a flat, clean surface.
    • Use a Phillips screwdriver to remove the eleven 6.6 mm‑long screws from the back cover.
  3. Acer Aspire 3 A315-24P-R7VH SSD Replacement, Remove the back cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH SSD Replacement, Remove the back cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH SSD Replacement, Remove the back cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the long edge of an opening pick straight down between the chassis and the back cover at the rear of the laptop
    • Pry up to release a few back cover clips and position the opening pick flat under the back cover.
    • Slide the pick along the rear edge of the laptop to release the clips.
  4. Acer Aspire 3 A315-24P-R7VH SSD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH SSD Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH SSD Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry around the entire perimeter until the back cover releases.
  5. Acer Aspire 3 A315-24P-R7VH SSD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH SSD Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH SSD Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the back cover off the chassis and remove it.
    • If the back cover is stuck, repeat the previous step to release any remaining clips.
  6. Acer Aspire 3 A315-24P-R7VH SSD Replacement, Peel back the tape: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH SSD Replacement, Peel back the tape: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers or your fingers to peel away the tape covering the battery connector.
  7. Acer Aspire 3 A315-24P-R7VH SSD Replacement, Disconnect the battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH SSD Replacement, Disconnect the battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to push down on either side of the battery cable connector until it comes out of its socket.
  8. Acer Aspire 3 A315-24P-R7VH SSD Replacement, Remove the battery screws: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH SSD Replacement, Remove the battery screws: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 4.7 mm‑long screws securing the battery.
  9. Acer Aspire 3 A315-24P-R7VH SSD Replacement, Remove the battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH SSD Replacement, Remove the battery: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH SSD Replacement, Remove the battery: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the battery out of the chassis and remove it.
  10. Acer Aspire 3 A315-24P-R7VH SSD Replacement, Remove the SSD screw: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH SSD Replacement, Remove the SSD screw: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the one 4.9 mm‑long screw securing the SSD.
  11. Acer Aspire 3 A315-24P-R7VH SSD Replacement, Remove the SSD: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH SSD Replacement, Remove the SSD: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the SSD by its edges and pull it straight out of its socket to remove it.
    • Don't pull up at a sharp angle, as this could damage the SSD and its socket.
Take your e-waste to an R2 or e-Stewards certified recycler. Acer partners with different e-waste recycling programs that vary by region, click here to see where you can properly dispose of your e-waste.
Kara Piepenbrink
crwdns2935283:005/31/24crwdne2935283:0
4 472 crwdns2915208:0crwdne2915208:0
crwdns2935297:021crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:021 113crwdne2935297:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 53
