Acer AL2216W Capacitor Replacement
  1. crwdns2935267:0crwdne2935267:0
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
  2. Acer AL2216W Capacitor Replacement, Discharge the old capacitors: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • CAUTION: If you are uncertain about handing high voltage parts, follow all provided warnings! A capacitor discharge tool is STRONGLY RECOMMENDED.
    • The filter capacitor will hold the most residual charge. Use caution around this capacitor!
    • Unplug the monitor for 24-48 hours. Wait 5-7 days before swapping the filter capacitor.
  3. Acer AL2216W Capacitor Replacement, Remove the stand: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer AL2216W Capacitor Replacement, Remove the stand: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • EET owners: Your kit has this bit. No purchase needed.
    • This monitor never came with a hinge cap. If yours has one, unclup the marks in black.
    • Remove the 4 screws from the monitor stand with a Philips #1 screwdriver. Remove the bottom screws first.
  4. Acer AL2216W Capacitor Replacement, Remove the back of the monitor: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer AL2216W Capacitor Replacement, Remove the back of the monitor: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Sort this screw separately, as it is unique.
    • Remove 4 fine threaded screws from the back of the monitor with a Phillips #0 screwdriver. All of these screws are the same.
  5. Acer AL2216W Capacitor Replacement, Unlatch the clips (Bottom): crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer AL2216W Capacitor Replacement, Unlatch the clips (Bottom): crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Jimmy
    $7.95
    • If the monitor has never been serviced, you may have to use a flathead screwdriver, Jimmy or a Heavy duty spudger. This will damage the plastic somewhat and is unavoidable. In some cases, you may be able to use a plastic pry tool instead of metal to avoid the damage, but not every time.
    • Open the monitor at the bottom of the monitor by releasing the four tabs with a flathead screwdriver or a Jimmy and plastic pry tool. If force is needed, the best way to do this is to put electrical tape on a flathead screwdriver and split the panels.
  6. Acer AL2216W Capacitor Replacement, Unlatch the clips (Side): crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you are having trouble doing this, use a pry tool. An unserviced monitor may not come up as easily.
    • With the monitor unclipped on the bottom, pull the sides of the monitor up. Do this slowly to avoid cracking the LCD.
  7. Acer AL2216W Capacitor Replacement, Remove the IEC socket screws: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After these screws are removed, the power supply will be exposed.
    • With the back of the monitor off, remove the 2 screws on the IEC power connector using a Phillips #0 screwdriver.
  8. Acer AL2216W Capacitor Replacement, Remove the video connection screws: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • EET owners: Your bit does not have this kit. Step 1 covers the current recommendation (Pro Tech Go or HF toolkit). If you want a cheap way to augment an existing EET, the Hart 61-bit screwdriver kit (Standalone) is a well made low-cost addition that includes the required 5mm bit that I have personally tested). The Mako driver kit (Refurbished, when available) also has the 5mm bit.
    • Needlenose plyers can be used in place of the nut driver. However, it will be hard to properly re-tighten the screws.
    • Remove the 4 screw pins for the video cables from the monitor. Use a 5mm Nut bit/driver to remove the screw pins from the power supply shield.
  9. Acer AL2216W Capacitor Replacement, Disconnect the backlight cables: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer AL2216W Capacitor Replacement, Disconnect the backlight cables: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the CCFL cables from the power supply board.
  10. Acer AL2216W Capacitor Replacement, Disconnect the button board: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer AL2216W Capacitor Replacement, Disconnect the button board: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Board removal is optional.
    • Disconnect the flat flex cable that goes to the control board.
  11. Acer AL2216W Capacitor Replacement, Remove the power supply shield (Part 1): crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer AL2216W Capacitor Replacement, Remove the power supply shield (Part 1): crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2 lower screws that hold the power supply shield to the monitor with a Phillips #0 screwdriver.
  12. Acer AL2216W Capacitor Replacement, Remove the power supply shield (Part 2): crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer AL2216W Capacitor Replacement, Remove the power supply shield (Part 2): crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer AL2216W Capacitor Replacement, Remove the power supply shield (Part 2): crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The lower shield does not have to be removed. However, it will make disassembly easier.
    • On the right side of the monitor, remove the remaining Phillips #0 screws holding the board shield in place.
    • Lift the lower plate up while removing the power supply shield to remove it from the monitor. Once this is done, you will have access to the power supply.
    • Removing the lower shield (Optional): To remove the lower shield, release the black tabs holding it in place, and lift up. Do this for all the tabs holding it in place.
  13. Acer AL2216W Capacitor Replacement, Remove the power supply: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer AL2216W Capacitor Replacement, Remove the power supply: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer AL2216W Capacitor Replacement, Remove the power supply: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • IF YOU ARE REPLACING THE FILTER CAPACITOR, IT MUST BE DISCHARGED BEFORE REMOVAL FOR SAFETY!
    • The black screw is a ground screw and must be placed in the same location when reassembling the monitor. The remaining 3 screws can be installed in any order when reinstalling the power supply.
    • Any bulged capacitors are likely to have a residual charge, and the power supply should be handed with this assumption in mind if you see any visibly bulged capacitors.
    • With the power supply shield removed from the monitor, identify the power supply. Take note of the printed values, including the inverter cap (if present).
    • Remove the 4 Phillips #1 screws from the power supply. Once this is done, lift up the power supply at a slight angle to clear the chassis. Do not lift too much or the connector may be damaged!
    • This capacitor is only found on older power supplies. Replacement is optional, but recommended.
  14. Acer AL2216W Capacitor Replacement, (Optional) Capacitor polarity marking: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If the PCB is marked to avoid mis-installation, the flux will wash these marks off.
    • If you are unsure of the position of the capacitors, mark the polarity with a permanent marker. If the capacitors are incorrectly installed, they will explode when power is applied.
  15. Acer AL2216W Capacitor Replacement, Add flux to the capacitor leads: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you do not have flux on hand, solder can be used. Some flux is difficult to clean if overused.
    • To prepare the board for capacitor replacement, add flux or solder.
  16. Acer AL2216W Capacitor Replacement, Remove the old capacitors: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer AL2216W Capacitor Replacement, Remove the old capacitors: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer AL2216W Capacitor Replacement, Remove the old capacitors: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use of a Helping Hands is recommended to avoid soldering iron contact. If you do not have one, hold the board at an angle.
    • While a partial replacement may work, the remaining capacitors will fail. It is best to do them all while servicing the failed ones. Refer to this guide for a soldering "how to".
    • Move to a workspace with ventilation or use a fume extractor. Once in an appropriate workspace, desolder the old capacitors. Heat up each leg and remove it.
    • After removing the capacitors, clean up the old solder with a desoldering braid. Lift it with the iron when removing it.
  17. Acer AL2216W Capacitor Replacement, Installing brand new capacitors: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Check the capacitor polarity before soldering the new capacitors in. Incorrectly installed capacitors will explode with power applied!
    • Install the new capacitors. Check the polarity and bend the leads so they do not come loose during installation.
  18. Acer AL2216W Capacitor Replacement, Solder the new capacitors in: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer AL2216W Capacitor Replacement, Solder the new capacitors in: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer AL2216W Capacitor Replacement, Solder the new capacitors in: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the polarity is verified, solder the capacitors in. After installation, cut off any excess lead.
  19. Acer AL2216W Capacitor Replacement, Clean the flux off of the board: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After verifying there are no cold solder joints, clean the board with 91%+ Isopropyl alcohol, or denatured alcohol.
  20. Acer AL2216W Capacitor Replacement, Test the monitor: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put the monitor back together and test the repair.
crwdns2935229:012crwdne2935229:0
Nick
crwdns2935283:011/10/09crwdne2935283:0
94,371 crwdns2915208:0crwdne2915208:0
crwdns2935297:059crwdne2935297:0
crwdns2947412:028crwdne2947412:0
I did not replace the large capacitor on the Acer monitor yet. All other caps have been replaced. I may have to replace the FSPO55- ZP102A as it has a hot spot beside it. I don't know if the part number is right? Do know where I can buy it. Tom B
Thomas Brady - crwdns2934203:0crwdne2934203:0
These older CCFL panels usually burn on the PCB by the inverter coil and main transformer (the Delta branded part, in this case). The LED monitors limit the failure points to the transformer.
It sounds like your PCB got burned from the heat by the transformer or the inverter coil. This is very common and the boards are designed to take it. However, if you are concerned you should buy a new power supply board altogether if that makes you more comfortable.
Nick -
In step 12, replacing the capacitors with ones with a different capacitance rating instead of using a capacitor rated for higher voltage makes no sense to me electrically. The capacitance rating is the important part, if you use a capacator rated for say 35 volts when the original is rated for 10 makes no difference whatsoever. the rating just means MAX voltage.
Brennan Gomolka - crwdns2934203:0crwdne2934203:0
Thanks @nick! Just waiting for the parts to come in!
Aiden - crwdns2934203:0crwdne2934203:0
@nick which one is the filter capacitor?
Aiden -
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 115
crwdns2942667:0crwdne2942667:0 23,446
