Accessing Apple Cinema Display M8149 Control Boards
  1. Accessing Apple Cinema Display M8149 Control Boards, Control Boards: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Accessing Apple Cinema Display M8149 Control Boards, Control Boards: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Accessing Apple Cinema Display M8149 Control Boards, Control Boards: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before starting, make sure the display is unplugged.
    • Place the Cinema Display so that it is lying on its face and the feet are pointed away from you.
    • Remove the three screws (9.52 x 4.43mm) that connect the back foot to the hinge using the Hex Key.
    • Remove the back foot from the hinge mount by grabbing the foot and pulling upwards.
    Mine had hex head screws instead of Phillips head.
    Bill Greene - crwdns2934203:0crwdne2934203:0
  2. Accessing Apple Cinema Display M8149 Control Boards: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Accessing Apple Cinema Display M8149 Control Boards: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Accessing Apple Cinema Display M8149 Control Boards: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the eighteen (5.25 x 4.43 mm) screws around the edge of the backplate using the Hex key.
    • Disconnect the small white connector leading to the display's Power button.
    • Gently lift the backplate off of the display. Completely remove the backplate and set it aside.
    AND: Shall we mention right here, there is a small white connector leading to the display's POWER button that should be disconnected to slide the back plate off.
    spudmcat - crwdns2934203:0crwdne2934203:0
    These screws too were hex head, not PH2, on my display.
  3. Accessing Apple Cinema Display M8149 Control Boards: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Accessing Apple Cinema Display M8149 Control Boards: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the four (9.52 x 3.43 mm) screws on the outer rim of the metal cover.
    • Next, remove the four cover (11.91 x 2.89 mm) screws located at the corners of the metal cover using the Phillips #2 screwdriver.
    Here and on the next step you’ll m
    need a PH 2 screwdriver
    dietrichbatista - crwdns2934203:0crwdne2934203:0
  4. Accessing Apple Cinema Display M8149 Control Boards: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Accessing Apple Cinema Display M8149 Control Boards: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Accessing Apple Cinema Display M8149 Control Boards: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the large brown plug in the center-right, that connects the control board to the rest of the display.
    • Unplug the blue and gray plug on the right side of the control board. Repeat with the left side.
    There are 2 Phillips screws at the center top and center bottom that need to be removed as well. They are parallel to the work surface if the screen is flat. The control board must be lifted slightly to access the screws. There's also a clip holding the disconnected power connector to the mechanisms below.
    About This Matt - crwdns2934203:0crwdne2934203:0
  5. Accessing Apple Cinema Display M8149 Control Boards: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Accessing Apple Cinema Display M8149 Control Boards: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the large metal cover which spans across the back of the whole display.
Brett Murphy
crwdns2935283:004/01/11crwdne2935283:0
197 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-41, Forte Spring 2011 crwdns2935289:0Cal Poly, Team 10-41, Forte Spring 2011crwdne2935289:0
CPSU-FORTE-S11S10G41
crwdns2935297:018crwdne2935297:0
thank you for this guide. my 22" adc didn't want to start up. after following this guide, it now works with my G4. thank you
thereddrag0n - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,765
