Abask A8 Speaker Replacement
  1. Abask A8 Speaker Replacement, Internal Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Abask A8 Speaker Replacement, Internal Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Abask A8 Speaker Replacement, Internal Assembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the four 1.6 mm screws on the front plate.
    • Gently insert a pry between the front panel and the main body, working around the edges to pop it off.
    • Pull the main body from the shell.
    • Be careful not to damage the ribbon cable, as they are very fragile. Ribbon cables look like thin pieces of silver duct-tape.
  2. Abask A8 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Abask A8 Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the four 1.6 mm screws that secure the screen.
  3. Abask A8 Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Abask A8 Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Abask A8 Speaker Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the internal facing camera with care not to strain the connected ribbon cable.
    • Lift up the black ZIF locking flap and disconnect the ribbon cable.
  4. Abask A8 Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Abask A8 Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Abask A8 Speaker Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the camera connector ZIF locking flap.
    • Gently remove the ribbon cable from the connector and fully remove the camera.
  5. Abask A8 Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Abask A8 Speaker Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Jimmy prying tool, lift the supercapacitor out of its slot.
    • Be careful not to puncture the supercapacitor.
  6. Abask A8 Speaker Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Abask A8 Speaker Replacement, Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the ZIF locking flap that is securing the ribbon cable connecting the motherboard to the shell.
  7. Abask A8 Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Abask A8 Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the ribbon cable locking flap and disconnect the ribbon cable from the motherboard.
    • Carefully separate the motherboard from the screen.
  8. Abask A8 Speaker Replacement, Photodiode: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently release the silver locking flap that is holding the ribbon cable connecting the photodiode to the motherboard.
    • Carefully pull the flat ribbon cable out of the connector.
  9. Abask A8 Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Abask A8 Speaker Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the four 1.6 mm screws that secure the photodiode.
    • Carefully lift the old photodiode out of its base.
    • To avoid damaging the photodiode, make sure to place it face down on a clean, static-free surface when not handling it.
  10. Abask A8 Speaker Replacement, Speaker: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Abask A8 Speaker Replacement, Speaker: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Abask A8 Speaker Replacement, Speaker: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Removing the photodiode will expose the speaker, connected by wires.
    • Using a soldering iron, desolder the speaker connections from the motherboard.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Lindsey Fennell
crwdns2935283:003/18/25crwdne2935283:0
341 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-4, Konn Spring 2025 crwdns2935289:0UMass Dartmouth, Team 4-4, Konn Spring 2025crwdne2935289:0
UMASSD-KONN-S25S4G4
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 72
