ASUS VivoBook S400C CPU Fan / Heat Sink Assembly Replacement
  1. ASUS VivoBook S400C CPU Fan / Heat Sink Assembly Replacement, Remove the Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C CPU Fan / Heat Sink Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS VivoBook S400C CPU Fan / Heat Sink Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C CPU Fan / Heat Sink Assembly Replacement, Disconnect the Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C CPU Fan / Heat Sink Assembly Replacement, Heat Shield: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS VivoBook S400C CPU Fan / Heat Sink Assembly Replacement, Heat Shield: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the black shield covering the display connector and the heat sink.
    • You may need to use double-sided adhesive tape to resecure the shield.
  5. ASUS VivoBook S400C CPU Fan / Heat Sink Assembly Replacement, CPU Fan / Heat Sink Assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C CPU Fan / Heat Sink Assembly Replacement, CPU Fan / Heat Sink Assembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C CPU Fan / Heat Sink Assembly Replacement, CPU Fan / Heat Sink Assembly: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the fan.
    • Grasp the plug with a fingernail on either side and pull it straight out from the connector.
  6. ASUS VivoBook S400C CPU Fan / Heat Sink Assembly Replacement, Remove the Fan and Heatsink Screws: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 5 mm screws securing the fan.
    • Remove the four 3 mm screws securing the heat sink.
    • Removing the screw covered by the warning label will void your warranty.
  7. ASUS VivoBook S400C CPU Fan / Heat Sink Assembly Replacement, Remove the Fan and Heatsink: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the fan and heatsink straight up to remove it.
    • Before reassembly it is essential to clean off the old thermal paste from the processor and the heatsink and to apply new. How to apply thermal paste explains how.
Jerry Wheeler
crwdns2935283:003/21/22crwdne2935283:0
76,189 crwdns2915208:0crwdne2915208:0
crwdns2935297:071crwdne2935297:0
crwdns2942667:0crwdne2942667:0 324
