ASUS Vivo AiO V241IC HDD and RAM Replacement
Konstantin Epikhin
crwdns2944107:0crwdnd2944107:0Konstantin Epikhincrwdnd2944107:0crwdnd2944107:0crwdnd2944107:04crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Kul 3, 2025crwdne2944111:0
crwdns2931287:020crwdne2931287:0
crwdns2937799:0crwdne2937799:0
crwdns2944444:0crwdne2944444:0
crwdns2942287:0crwdne2942287:0
Recently i bought a new device ASUS All-In-One V241 and it has very slow HDD Toshiba and 4Gb RAM DDR4.
This is my first replacement guide - i hope it will be helpful for you :)
  1. ASUS Vivo AiO V241IC HDD and RAM Replacement, Remove 4 screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off your device
    • Place it horizontaly on the stable ground
    • Remove 4 screws at the bottom of the display
    • Take grey panel from the sides and pull it up
    • Be careful to pulling up - there are two connectors, which goes from display to motherboard. You can safelly lift display for 5-7 cm (like on the photo)
  2. ASUS Vivo AiO V241IC HDD and RAM Replacement, Lift up display: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS Vivo AiO V241IC HDD and RAM Replacement, Lift up display: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS Vivo AiO V241IC HDD and RAM Replacement, Lift up display: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After disconnecting two connectors from the motherboard you can lift display up
    • There is an also connector to display from motherboard and do not hurry to lift up display
    • There is no metal cover from the motherboard on this photo
  3. ASUS Vivo AiO V241IC HDD and RAM Replacement, HDD: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS Vivo AiO V241IC HDD and RAM Replacement, HDD: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS Vivo AiO V241IC HDD and RAM Replacement, HDD: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now you can see motherboard, covered up by metal cover
    • HDD - on the left side. Remove screws and pull HDD-case
  4. ASUS Vivo AiO V241IC HDD and RAM Replacement, RAM: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS Vivo AiO V241IC HDD and RAM Replacement, RAM: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS Vivo AiO V241IC HDD and RAM Replacement, RAM: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove screws from the metal cover and pull up - you can see the motherboard
    • RAM - 2 Slots, DDR4 2400 Mhz
  5. ASUS Vivo AiO V241IC HDD and RAM Replacement, Motherboard front side overview: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS Vivo AiO V241IC HDD and RAM Replacement, Motherboard front side overview: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS Vivo AiO V241IC HDD and RAM Replacement, Motherboard front side overview: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Here you can find more details of the V241ICR-R rev 2.0 mainboard.
    • This refers to V241ICGK-BA111T model of the PC
  6. ASUS Vivo AiO V241IC HDD and RAM Replacement, Accessing SSD slot: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS Vivo AiO V241IC HDD and RAM Replacement, Accessing SSD slot: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS Vivo AiO V241IC HDD and RAM Replacement, Accessing SSD slot: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all marked screws to get to the other side of the mainboard.
    • Dont forget the central one, the Fan and all the cables before lifting the MB. It goes up easy but may be some sticky glue below.
  7. ASUS Vivo AiO V241IC HDD and RAM Replacement, Motherboard back side overview: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS Vivo AiO V241IC HDD and RAM Replacement, Motherboard back side overview: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS Vivo AiO V241IC HDD and RAM Replacement, Motherboard back side overview: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Here you can find NGFF M.2 (key M) slot for 2280 size SSD.
    • Install any AHCI (mSATA) SSD. Modules with both keys B+M are OK. Note that NVME and other PCI-E/USB modules are NOT supported.
    • You may need an extra srew to fix your new SSD in the slot.
    • Reasseble the system in reverse order
crwdns2935229:015crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Konstantin Epikhin
crwdns2935283:009/20/17crwdne2935283:0
492 crwdns2915208:0crwdne2915208:0
crwdns2947412:034crwdne2947412:0
Приветствую, Константин. Спасибо за подробный отчет по разбору. Сейчас стоит вопрос о приобретении такого же моноблока, однако есть важный нюанс, который меня интересует. Планирую сразу поставить SSD, но 1ТБ жесткий диск хотелось бы оставить как второй накопитель. На сайте производителя заявлено, что в топовой комплектации наряду с 1Тб HDD установлен ещё и SSD стандарта M2 (https://www.asus.com/All-in-One-PCs/Vivo...). У вас на 2 шаге, третье фото видна сама материнская плата, однако не совсем понятно есть ли на ней такой разъем. Есть что-то похожее на него в верхнем правом углу, как раз где вы красным прямоугольником обозначили область шлейфа дисплея. Можете выложить это фото без прямоугольника в хорошем разрешении или отправить мне на почту rf_c(собака)mail.ru. Буду очень признателен!
Viktor Che - crwdns2934203:0crwdne2934203:0
могу на днях посмотреть если еще актуально
Konstantin Epikhin -
инструкция хорошая, но, к сожалению, для меня не полная. после снятия крышки с материнской платы выяснилось, что память накрыта дополнительной железной крышечкой. пока думаю как ее снимать.
Roman Vasilenko - crwdns2934203:0crwdne2934203:0
вы имеете ввиду крышку на материнской плате? сама память у меня не была ничем не прикрыта
разобрался. с боков крышки есть вырезы, куда можно просунуть отвертку. надо потянуть вверх - она отщелкивается (винтов нет).
можно ли добавить отдельно ssd?
Pavel -
там только один разъем sata. разъема m2 так же нет. т.е. 2-й диск не вставить.
извиняюсь за столь поздний ответ - да, m2 там, к сожалению, нет. я в своем случае ставил гибридный диск - дает хороший прирост при своей цене и объеме
Спасибо всем, что отписались. Моноблок в итоге купил, вчера попробовал, придется все равно менять на SSD, т.к. даже голая винда грузится долго, а террабайтничек родной во внешний бокс придется запихать, жаль не распаяли на плате M2 или еще один вывод на SATA устройство, интересно, что в BIOSe до 4 SATA устройств поддержка есть.
ребята, спасибо вам! как же я намучился с дефолтным хардом! прочитал и прям завтра займусь заменой. отпишу по результатам
Андрей Фисенко - crwdns2934203:0crwdne2934203:0
если не сложно, напишите какой кто выбрал накопитель на замену?
Константин подскажите пожалуйста модель диска ssd и модель оперативки , которые вы установили)))
andrew38russ - crwdns2934203:0crwdne2934203:0
День добрый!
Модуль памяти SODIMM DDR4 8GB Kingston KVR24S17S8/8
Жесткий диск SATA 2TB SeagateST2000LX001
Но диск лучше взять 7200 RPM
приветствую!
интересует момент с заменой hhd.
как вы переносили саму винду?
или вы все устанавливали на новый диск с чистого листа?
Viachesalv - crwdns2934203:0crwdne2934203:0
Делал на всякий случай полный бекап системы на внешний диск. Также вытащил из BIOS ключ на Windows 10 Home - обратите внимание, что валидация ключа проходит по идентификаторам оборудования, так что при смене HDD может потребоваться повторная и ручная активация - для этого вам понадобится ключ, который в этом моноблоке зашит в BIOS. Вытащить его можно множеством утилит.
И систему ставил на полностью чистый диск
Прочитал на одном ресурсе, что все таки есть m2 разъем на материнской плате, находиться с обратной стороны, к сожалению нет возможности это проверить.
Алексей Смирнов - crwdns2934203:0crwdne2934203:0
Сам написал, сам отвечаю, на конфигурации с процом 6006U нет разъема под m2, видимо платы немного разные.
Алексей Смирнов -
У меня есть штатный разьем М.2 с обратной стороны. Мать V241ICR-R rev 2.0
Поставил туда 970 Evo NVMe в биосе не видит, В биосе все перелопатил, не видит и все.
биос стоит последний он отличается и идет именно для -R
остается уповать на техподдержку асуса.
Alexandr - crwdns2934203:0crwdne2934203:0
что нибудь ответила поддержка? тоже хочу поставить ssd, но не знаю какой подойдет.
Александр Ж. -
Штатный разъем М.2 находится на обратной стороне платы. Снять плату не составляет труда, главное перед этим аккуратно отсоединить все разъемы. Вот сфоткал плату с разъемом https://drive.google.com/open?id=1ppY5jJ...
Александр Ж. - crwdns2934203:0crwdne2934203:0
спасибо большое за пояснение и фото - не додумался снять плату изначально. при случае попробую обновить мануал. подскажите, пожалуйста, полное название вашей модели моноблока и материнской платы.
Моноблок V241ICGK-BA111T , а модель платы не знаю. Где ее посмотреть? И может Константин вы подскажете какой SSD туда можно впихнуть? Они же бывают разных интерфейсов :Sata, PCI-E x 4, так же могут по протоколу AHCI работать или NVMe. Как узнать какие из них поддерживает материнка?
Я сам использую Samsung EVO (SATA). До M2 не добрался еще. Посмотреть полную модель можно в утилитах вроде Everest (AIDA64)
По поводу поддержки лучше думаю вначале узнать модель материнки, может найдется спецификация на порт. M2 довольно разнооразные бывают, в частности по требованиям питания.
Как вариант, попробуйте рассмотреть гибридный HDD+SSD + M2 плату Intel Optane Memory. Это плата именно для кеша - если примерно одинаковую работу делаете за моноблоком то подойдет идеально и не в ущерб памяти. В некоторых моментах эта связка работает быстрее чем SSD (в некоторых, но в целом прирост хороший)
Поставил такой SSD Samsung 860 EVO Series MZ-N6E250BW 250GB - встал как родной. Осталось установить на него систему.
Отчитываюсь по успешному upgarde ASUS Vivo AiO V241IC
Модель V241ICGK-BA111T (Core i5 8250U/GT930MX/1Tb/4Gb-DDR4-2400T/Win10HSL)
Под теплораспределительной металлической крышкой (metal cover упомянутый в шагах 3 и 4 данного руководства, видна слева на фото шаг 2) находится плата.
Модули памяти прикрыты еще одной металлической крышкой из тонкого металла с отверстиями. В нижней части эта крышка слегка приклеена к пластику разьёма верхнего модуля DDR - клипсы эту металлическую крышечку не держут вообще они просто как направляющие, а вот клей держит хорошо и при снятии крышеску легко погнуть, но это не критично.
На обратной стороне платы находится NGFF разъём под SSD M.2 (key M). Туда как родной встаёт любой AHCI (mSATA) модуль с ключами B+M. Плата НЕ поддерживает NVME и прочие PCI-E/USB варианты.
Поддержка SSD mSATA (AHCI) - проверял на SSD SanDisk X600 M.2 2280 128G - определился и без проблем работает.
SSD NVMe (PCI-E) не поддерживает - проверял на Samsung 960 Evo NVMe
Добавил ещё фото сюда.
iZelik - crwdns2934203:0crwdne2934203:0
винда загрузилась с винта, активировалась через инет, затем я просто начисто с флешки установил новую чистую десятку на ssd, а hdd в процессе установки полностью очистил. винда без мусора от асус загрузилась и активировалась без проблем.
iZelik -
спасибо за подробное описание!
Привет всем счастливым обладателям данного моноблока! Скажите кто уже пробывал сколько в данный моноблок можно поставить оперативной памяти? В нем на скриншотах было 2 слота - обычно ставят 2 по 8 gb, возможно ли поставить 2 планки по 16 gb или он не будет видеть такое количество (вроде процессор i5 8 поколения). Спасибо.
Антон Апраев - crwdns2934203:0crwdne2934203:0
подскажите, пожалуйста! взял сей комп и разочаровался!!! всё тормозит хуже чем на старом компе. вроде по отзывам грешить на процессор не приходится - рейтинг проца хороший. в чём может быть дело? кто-нибудь сталкивался с такой проблемой? я уже и винду ставил и 7-ку и 10-ку…всё бесполезно…думаю о несовместимости какого-то железа…
Арсений Кабанов - crwdns2934203:0crwdne2934203:0
Арсений, самое проблемное в этом моноблоке - это жесткий диск. покупал данный девайс с упором на дальнейший апгрейд. заменил hdd на ssd и теперь не имею проблем. инструкция по разбору была для этого и создана
Отпишусь сюда, моноблок Asus V241ICGK-BA022T [90PT01W1-M00520] мать V241IC rev 2.0, разъем m.2 не распаян
Дмитрий Согрин - crwdns2934203:0crwdne2934203:0
Спасибо за гайд! Моноблок ASUS V222, материнка была дополнительно закрыта металлической крышкой. ОЗУ также была прикрыта алюминиевой коробочкой, которую не так просто было отодрать.
Поставил SSD Samsung 860 EVO, и добавил плашку оперативы SODIMM DDR4 8GB Kingston KVR24S17S8/8. Рисковать с покупкой NVME не стал - скорее всего по-прежнему не поддерживается.
Добавил бы, что для открытия корпуса может помочь обычная пластиковая карта, которой можно провести по краям (без этого открыть корпус сложно и возможно опасно).
1 1 - crwdns2934203:0crwdne2934203:0
Всем привет.
Есть моноблок ASUS Vivo AiO V241ICGK-BA022T купил планку RAM SODIMM DDR4-2400 8Gb Kingston (KVR24S17S8-8).
Пробовал поставить:
1 вариант - 4гб + 8гб(купленный) и 8гб(купленный) + 4гб - не определяет вообще - видно только 4гб(родные)
2 вариант - просто 8гб(купленный) без родного модуля - компьютер не загружается,пробовал в 2 разных разьема.
Win 10 64bit, макс. поддержка 32 гб оперативной памяти.
В чем может быть проблема?
Планка оперативной памяти рабочая. Сдал в сервис, причина - не определяет, вернули - сказали все работает.
Evgeniy - crwdns2934203:0crwdne2934203:0
The V241IC I just worked on had four cables to be disconnected, not two, to detach the screen completely from the motherboard. These is no picture here of the cover over the motherboard, either, but that is a no-brainer to figure out. It’s nice that Asus used the same size and thread of screws throughout this repair.
Like the original motivation of this article, I had to replace a pathetic 1TB 5400rpm Seagate drive with a solid state drive. Now the V241IC operates like a real computer, booting up and responding quickly. What Asus would cripple this nice all-in-one with a slug-slow hard drive is beyond me. Better to start with solid state and charge more, rather than going for cheap.
Ben Myers - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 50
crwdns2936753:030crwdne2936753:0 207
crwdns2942667:0crwdne2942667:0 26,005
