Need to access the internals of your ASUS VG248? Here's a guide that shows how to remove the frame and open the display.
Four rubbery covers hide four screws in the rear of the monitor.
Pry out the plastic covers with a stiff pointed tool, like a metal spudger.
Remove the four 13.4 mm Philips #1 screws securing the monitor stand.
Lay the cloth over one of the long edges of the display.
Grip the side of the bezel through the cloth and lift straight up. A few clips in the center will pop free.
Repeat the procedure around the display, lifting up the center of the next side.
Move around to the other long side and lift up on the center of the bezel.
Grip the center of the final side and lift the bezel away from the rear case.
Now that you've freed the centers of the four sides, it's time to move on to the corners.
crwdns2935267:0crwdne2935267:0Jimmy$7.95
Using a thin stiff prying device, like a Jimmy, press in against the bottom clip in the lower left corner (beneath the HDMI logo).
While pressing the clip in, pull up on the lower edge of the bezel. The entire corner should pop free.
Once you've freed one corner, you should be able to gently twist the bezel off, freeing all of the remaining corners.
If any corners are particularly stubborn, repeat the previous step on the difficult corner.
With the casing removed, you now have access to the button board, cables, and the housing over the motherboard components.
crwdns2935229:022crwdne2935229:0
crwdns2947412:010crwdne2947412:0
Do you know of any place that sell the replacement lcd screen?
Hi there, I have a little thunderbug trapped in the LCD is it possible to take the metal casing at the front of to reomve said bug? Thanks
You could yes, but be very careful NOT to introduce dust into the panel!
Hi. A really small bug got stuck within my screen and I accidentally squished it so now it’s dead in there and I want to clean it. How would I remove the top layer of the screen? Because from what I can see it seems like it got squished between the glass and the actual LCD screen itself.
Guide to disassemble vg259qm
What power adapter and power cord is for gaming monitor Asus vg245qg? It was losted during moving.
https://www.youtube.com/watch?v=vV_Lbh2B...
Thanks, just watch this video.
I have the same issue as TJ Grainger. I have a very tiny spider, about 1 CM big spider (I can see by how it moves and it's legs projected from a white background) behind my screen. This is going to be annoying...
Hi, My problem is that I received an old model Asus that was unfortunately stored in a damp place, so there was mold behind the plastic surface -ugly blotches on the screen, but otherwise the monitor is working fine. I would like to clean this. I disassembled as far as the aluminum casing section you show in Step 13. It seems very solidly put together. Has anyone tried further disassembly?, or got any tips on doing this?
hey ya, i tried it, and i couldnt get the &&^&^$^ clips off even tho i was doing it right and lifiing with every ounce of my strength, wouldnt &&^&^$^ budge, and now my monitors ruined due to ur piece of $@$* guide and monitor
