ASUS Transformer Book Flip TP500LA Motherboard Replacement
  1. ASUS Transformer Book Flip TP500LA Motherboard Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS Transformer Book Flip TP500LA Motherboard Replacement, Back Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS Transformer Book Flip TP500LA Motherboard Replacement, Back Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ten 10 mm Phillips #0 screws found on the computer's back case.
  2. ASUS Transformer Book Flip TP500LA Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS Transformer Book Flip TP500LA Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Heavy-Duty Spudger
    • Slide a heavy-duty spudger between the back case and the computer.
    • Slowly work around the edges to undo the clips to fully separate the back case from the computer.
    • Gently lift off the back case.
  3. ASUS Transformer Book Flip TP500LA Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS Transformer Book Flip TP500LA Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Heavy-Duty Spudger
    • Slide a heavy-duty spudger into the ZIF connector and gently flip up the retaining flap to open the connector.
    • Pull the blue tab to remove the ribbon.
  4. ASUS Transformer Book Flip TP500LA Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS Transformer Book Flip TP500LA Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 5 mm Phillips #0 screws.
    • Remove the single 6 mm Phillips #0 screw.
  5. ASUS Transformer Book Flip TP500LA Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS Transformer Book Flip TP500LA Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the heavy-duty spudger to pry the white 8-pin connector away from the motherboard.
    • Gently pull the connector away from the motherboard.
    • The black 8-pin connector on the motherboard is very fragile, so be careful when removing the white 8-pin connector.
  6. ASUS Transformer Book Flip TP500LA Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS Transformer Book Flip TP500LA Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the blue plastic opening tool to loosen and remove the three black wires from the battery.
    • Slide the battery out from the computer to remove.
  7. ASUS Transformer Book Flip TP500LA Motherboard Replacement, Fan: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS Transformer Book Flip TP500LA Motherboard Replacement, Fan: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the six 5 mm Phillips #0 screws.
  8. ASUS Transformer Book Flip TP500LA Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS Transformer Book Flip TP500LA Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS Transformer Book Flip TP500LA Motherboard Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grasp the top of the 3-pin connector with tweezers.
    • Wiggle the connector until it loosens itself from the motherboard.
    • Gently lift the connector from the motherboard attachment.
  9. ASUS Transformer Book Flip TP500LA Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the fan off the motherboard.
    • Attached to the fan is thermal pasting that needs to be reapplied when attaching the fan back to the motherboard. Follow this guide to reapply thermal pasting correctly.
  10. ASUS Transformer Book Flip TP500LA Motherboard Replacement, Motherboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the two display cables from the motherboard.
  11. ASUS Transformer Book Flip TP500LA Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS Transformer Book Flip TP500LA Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #0 screwdriver, remove the three screws holding the motherboard to the rest of the device.
  12. ASUS Transformer Book Flip TP500LA Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS Transformer Book Flip TP500LA Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the motherboard from the device.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Graham Haigood
crwdns2935283:002/23/21crwdne2935283:0
301 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S3-G3, Eggleston Spring 2021 crwdns2935289:0The Citadel Military College of South Carolina, Team S3-G3, Eggleston Spring 2021crwdne2935289:0
CMCSC-EGGLESTON-S21S3G3
crwdns2942667:0crwdne2942667:0 777
