Use this guide if you are experiencing any issues with the side mouse buttons on your ASUS ROG Spatha X.
Use the pointed edge of a spudger to remove the four soft rubber covers on the underside of the mouse.
Use the included Torx screwdriver, or a T3 Torx screwdriver, to remove the four 4 mm screws.
Lift the upper mouse cover up and off.
Disconnect the side button assembly ribbon cable from the motherboard.
Remove the two 5 mm Phillips screws inside the mouse.
Remove the mouse skate under the thumb rest.
Remove the last 5 mm Phillips screw.
Gently remove the side button assembly.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
