ASUS ROG G750JW-RS72-CB Display Assembly Replacement
  1. ASUS ROG G750JW-RS72-CB Display Assembly Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure you completely power down the computer before beginning this process.
    • With your finger, push this slide to the right. The battery should pop out of place.
  2. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery out of its place gently.
  3. ASUS ROG G750JW-RS72-CB Display Assembly Replacement, Hard Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the flap using a plastic opening tool.
    • Hold the flap back with your finger.
  4. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 5.2mm screw underneath the flap.
  5. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the screw is out, pull on the plastic tab to pull off the plastic cover.
  6. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 5.2mm screws holding the hard drive in place.
    • Gently pull the rubber hard drive mount to the side.
    • Pull the drive out.
    What size or technical specs number are these 5.2mm screws? I need to get some replacements as I've lost them
    Snuggly Sauropod - crwdns2934203:0crwdne2934203:0
  7. ASUS ROG G750JW-RS72-CB Display Assembly Replacement, Display Assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 8.5mm screws holding the bottom half of the laptop together.
  8. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take a metal separater and gently pry open the back end of the laptop halves.
  9. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the connector connecting the screen and the motherboard
  10. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 6.8mm screws holding the hinges of the screen to the bottom half of the computer.
    • Detach the screen from the hinges of the laptop.
    • Be careful not to damage the connecting wires when detaching the screen.
  11. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a metal separator to carefully separate the bottom half of the laptop.
  12. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently unplug the cables connecting the screen to the motherboard.
    • The display assembly can now be freely separated.
    Question, so is it really needed to take out the hard drives (ssds) in order to replace the top cover? I understand the keyboard needs to come out thats why Im asking.
    adeeb - crwdns2934203:0crwdne2934203:0
    hi how are u, thx, question, if i want to only replace my top cover. do i have to take out the hard drives (ssdd), or can I leave them in, cause I do understand I need to remove the keyboard?
crwdns2935229:05crwdne2935229:0
Sully Chen
crwdns2935283:001/22/18crwdne2935283:0
525 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S11-G5, Banghart Winter 2018 crwdns2935289:0Cal Poly, Team S11-G5, Banghart Winter 2018crwdne2935289:0
CPSU-BANGHART-W18S11G5
Super helpful.
Upon re-pasting GPU I noticed that not only GPU chip was covered in thermal paste surrounding chips were literately covered with thermal paste to is that normal?
Timepusher - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,027
