ASUS Q302L Battery Replacement
  1. ASUS Q302L Battery Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
    • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
  2. ASUS Q302L Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS Q302L Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS Q302L Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wedge a plastic opening tool under the rear case near the hinge.
    • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
  3. ASUS Q302L Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the cover is free from all the clips, remove the cover from the laptop.
  4. ASUS Q302L Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver and remove all five 5 mm screws securing the battery.
  5. ASUS Q302L Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS Q302L Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS Q302L Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently wedge a plastic opening tool under the connector.
    • Pry only on the connector not the socket itself or you risk damage to the motherboard.
    • Carefully lift the connector up away from the socket to disconnect it.
  6. ASUS Q302L Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS Q302L Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the screws and connector are removed, simply pull out the battery from its place.
khalifa
crwdns2935283:003/02/17crwdne2935283:0
110 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S13-G4, Cagle Spring 2017 crwdns2935289:0USF Tampa, Team S13-G4, Cagle Spring 2017crwdne2935289:0
USFT-CAGLE-S17S13G4
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 6,393
