One drop can mean the difference in having a usable tablet or not. That is why being able to replace a cracked or damaged screen is crucial to an electronics life span. Use this guide to replace the screen on your ASUS Eee Pad Transformer.
Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
Remove back panel by pulling away from the remaining device.
Use Phillips #00 Screwdriver to remove four 3 millimeter screws found on the metal panel.
TF101G has a flex print, probably the GSM antenna, glued on top of the metal panel. It is connected to a printed circuit board with a connector similar to that in step 8.
Use Plastic Opening Tool to pry off the metal panel from the battery starting on the right side corners and working around the rest of the panel.
In some cases the panel may not be glued because the glue got too old, or, as like in my case, the battery expanded
Peel off tape from around the edges of the battery.
Insert Plastic Opening Tool into slot on side of battery found near the wire bundle.
Lift up the battery off of the device.
e’ possibile avere le informazioni in italiano? Grazie
Use a Phillips #00 Screwdriver to remove the six 3 millimeter screws securing the motherboard to the screen.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Detach the Wifi and GPS antennas (three coaxial cables connected to the motherboard) using hands,metal spudger, or tweezers by lifting away from the device.
Use fingers, plastic opening tool, or metal spudger to lift the clips to the ZIF connector. Remove the ribbon cables attached underneath.
Remove any tape that is holding down any free wires.
Carefully lift the motherboard and slide it out from underneath its constraints.
Unclip the ribbon cable from the ZIF connector using a plastic opening tool or metal spudger.
Remove any taped on accessories
Use a Phillips #00 Screwdriver to remove the four 3 millimeter screws securing the two black ports at the bottom.
Use a Phillips #00 Screwdriver to remove the two 3 millimeter screws securing the charging port to the screen.
Carefully remove the charging port by lifting the metal end and carefully sliding the plastic attached underneath the grey screen constraint.
Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing volume button board.
Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the headphone jack board.
Unclip the No-fuss ribbon cable connector using your fingernail or metal spudger.
Use fingers, plastic opening tool, or metal spudger to lift the clip securing the display cable and remove by sliding it out.
Use fingers, plastic opening tool, or metal spudger to lift the glued-in left and right speaker.
Detach the Wifi and GPS antenna from the screen. This piece is glued down so use a metal spudger to get under the piece and lift up.
Use a metal spudger to lift up the small electric board next to the camera. This piece is glued down as well as secured by plastic pillars.
Using a metal spudger, lift the camera out of its spot. The camera is glued down.
Detach the two ZIF connectors using your fingers, plastic opening tool, or metal spudger.
Using a metal spudger lift up the glued down motherboard.
This is what the final screen should look like after everything is removed.
First Class for your Instruction.
With Best Regards
Jürgen Pogoda
If you have a device with SIM card slot, remove SIM card first.
Hans-Josef Hoffmann - crwdns2934203:0crwdne2934203:0
