ASUS Eee Pad Transformer Back Panel Replacement
Sandy Babich
crwdns2944107:0crwdnd2944107:0Sandy Babichcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:06crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Sun 3, 2020crwdne2944111:0
5 - 15 crwdns2931279:0crwdne2931279:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
Repairing a damaged back panel is very important, the back panel protects all the inner workings in the tablet and needs to be in good condition to prevent permanent damage in the device. Removing the back panel also allows access to everything inside of the device and is an essential first step to all other repairs involved with the TF101 Tablet.
crwdns2944105:0crwdne2944105:0
  1. ASUS Eee Pad Transformer Back Panel Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS Eee Pad Transformer Back Panel Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
    If you have a device with SIM card slot, remove SIM card first.
    Hans-Josef Hoffmann - crwdns2934203:0crwdne2934203:0
  2. ASUS Eee Pad Transformer Back Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS Eee Pad Transformer Back Panel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS Eee Pad Transformer Back Panel Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
    • The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
  3. ASUS Eee Pad Transformer Back Panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
  4. ASUS Eee Pad Transformer Back Panel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
  5. ASUS Eee Pad Transformer Back Panel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
  6. ASUS Eee Pad Transformer Back Panel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS Eee Pad Transformer Back Panel Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove back panel by pulling away from the remaining device.
Sandy Babich
crwdns2935283:009/23/14crwdne2935283:0
1.909 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-9, Forte Fall 2014 crwdns2935289:0Cal Poly, Team 13-9, Forte Fall 2014crwdne2935289:0
CPSU-FORTE-F14S13G9
what can I use to stick back the metalic edge?
Cathy Madzimure - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,973
