This is the ASUS Chromebook (Model C424MA-DH48F), here we will be guiding you though a full battery replacement for the ASUS Chromebook.
Reasons to replace the battery include:
- Overheating
- Reduced battery life
- Slow charging
- Swollen battery
- Laptop dying unexpectedly
After replacing the component if you plan on disposing of the old battery here is a link explaining proper battery disposal.
Use a Phillips #0 screwdriver to remove the eleven 6.9 mm screws that secure the lower case.
Insert an opening pick into the gap between the lower case and chassis.
Slide the pick around the entire perimeter of the laptop until the lower case fully releases.
Remove the lower case.
Use an opening tool to pop up the silver locking bar securing the battery connector.
Push the battery connector directly out of its motherboard port.
Carefully use the plastic prying tool and pop up the locking bar and lift the connector off with your hand.
Use a Phillips #0 screwdriver to remove the six 4.1 mm screws that secure the battery.
Unseat the speaker cable from the black plastic hooks on the lower side of the battery.
Lift the battery up and out of the chassis.
For optimal performance, after completing this guide, calibrate your newly installed battery.
