APC Smart-UPS SC 450VA Battery Replacement
  1. APC Smart-UPS SC 450VA Battery Replacement, Remove the faceplate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull on the left corner of the faceplate to remove it.
    Ich würde die USV vorher noch vom Strom nehemen.
    HG Schlueter - crwdns2934203:0crwdne2934203:0
  2. APC Smart-UPS SC 450VA Battery Replacement, Unscrew the battery cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    • Use a PH2 screwdriver to unscrew the 4 screws securing the battery cover.
  3. APC Smart-UPS SC 450VA Battery Replacement, Remove the battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 APC Smart-UPS SC 450VA Battery Replacement, Remove the battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pull tab to pull out the battery.
    • Be sure to not pinch the cables between the case and the battery.
    • Unplug the battery connector.
    • Remove the battery.
    • Caution: Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals.
Sebastian
crwdns2935283:008/19/18crwdne2935283:0
29,477 crwdns2915208:0crwdne2915208:0
crwdns2935297:071crwdne2935297:0
this is incorrect, since 1995 all Smart UPS have hot swappable batteries. no need to turn it off, that's the whole point of it being in the front of the device - https://www.apc.com/us/en/faqs/FA303216/
Ryan Matthews - crwdns2934203:0crwdne2934203:0
Thank you, the guide has been adjusted.
Sebastian -
After hot swapping the battery replacement my replace battery LED is still lit. How do I reset that?
Michael Dickson - crwdns2934203:0crwdne2934203:0
You can press and hold the power button for a few seconds to manually run a self-test or just wait until it reaches the next scheduled self-test (every 7 or 14 days depending on configuration). It is recommended to wait at least 24 hours before performing the self test as the new battery needs time to reach capacity.
Sebastian -
crwdns2936753:07crwdne2936753:0 47
crwdns2936753:030crwdne2936753:0 213
crwdns2942667:0crwdne2942667:0 6,926
