8BitDo Pro 2 Trigger Replacement
crwdns2869540:0crwdne2869540:0: 810
6
48
212
810
crwdns2955950:0crwdne2955950:0: 1
crwdns2960002:01crwdne2960002:0.
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: 30 - 45 crwdns2931279:0crwdne2931279:0
If your 8BitDo Pro 2 controller trigger is unresponsive or not registering pressure correctly, the trigger mechanism may need to be replaced. This guide will walk you through removing and installing the trigger on your controller.
The trigger is responsible for registering pressure input during gameplay, allowing for control in actions such as aiming, braking, or accelerating. Over time, internal wear can affect how smoothly and accurate the trigger functions are.
Before using the guide, try cleaning the area. You should also test the controller on different devices and ensure it is set to the correct input mode, see the troubleshooting page for more information.
This repair will require you to open the controller. Before beginning, make sure to power off your controller.
    1. 8BitDo Pro 2 Trigger Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip the 8BitDo Pro 2 controller so that the back side is facing up.
    2. 8BitDo Pro 2 Trigger Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the battery cover off to remove it and expose the battery.
    3. 8BitDo Pro 2 Trigger Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your hands to remove the battery pack from the controller.
      • Do not bend or puncture the battery pack, this can be hazardous.
    1. 8BitDo Pro 2 Trigger Replacement, Controller: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the iFixit blunt tweezers, peel back the top two corners of the sticker located inside the battery compartment.
    2. 8BitDo Pro 2 Trigger Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a T6 Torx screwdriver to remove the four 5.0 mm screws from the back of the controller.
    3. 8BitDo Pro 2 Trigger Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 8BitDo Pro 2 Trigger Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 8BitDo Pro 2 Trigger Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the iFixit pick into the seam along the edge of the controller and slide it around to release the clips holding it together.
      • Leave opening picks in the space to keep the top and bottom case from reattaching.
      • Use an iFixit tool to carefully pry around the edges of the controller.
      • Once loosened, gently separate the top and bottom of the controller.
      • Do not separate the top and bottom sections, as they are still connected by a ribbon cable.
    4. 8BitDo Pro 2 Trigger Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 8BitDo Pro 2 Trigger Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a spudger to gently push up on alternating sides of the black plastic tab until it clicks up into its unlocked position.
      • Don't push the tab too hard or too far, otherwise it may come completely off the connector.
      • Use tweezers to gently pull the cable out of its socket.
      • The cable should be able to slide in and out of the socket with little to no force. If you feel resistance, the tab may not be fully unlocked.
      • During reassembly, insert the cable into its socket and use the flat end of a spudger to push the tab down into its locked position.
      • Separate the top and bottom casing of the controller.
      • If you feel resistance, check for any cables still connecting the two halves and avoid forcing them apart.
    1. 8BitDo Pro 2 Trigger Replacement, Trigger: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 8BitDo Pro 2 Trigger Replacement, Trigger: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • In the back shell, near the trigger assembly, use a finger to hold the small metal spring in place while removing the trigger cap.
      • This will prevent the spring from popping out and getting lost.
      • Use a spudger or opening tool to gently squeeze the two plastic locking hooks on the inside of the trigger cap.
      • Push the trigger cap outward through its slot until it pops free.
      • You may hear a click as the trigger disconnects.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Paige Lucas
crwdns2935283:003/03/26crwdne2935283:0
643 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-3, Rioux Spring 2026 crwdns2935289:0UMass Dartmouth, Team 5-3, Rioux Spring 2026crwdne2935289:0
UMASSD-RIOUX-S26S5G3
crwdns2936753:07crwdne2936753:0 48
crwdns2936753:030crwdne2936753:0 212
crwdns2959996:0crwdne2959996:0 810
