5. Software configuration
crwdns2869540:0crwdne2869540:0: 28
0
28
28
28
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: crwdns2931273:0crwdne2931273:0
      • This step is only needed because no custom firmware is available yet.
      • You can use the latest Bear Calibration firmware or the latest stock Prusa firmware.
      • Download gcode files using this link: https://github.com/gregsaun/bear_extrude...
      • Copy the following files to your SD card
      • bear_hemera_config_mk*.gcode (choose the version corresponding to your printer)
      • This file is used only once to configure your printer to use the Bear Hemera. You can reset this configuration anytime by running the reset_to_prusa_mk*.gcode
      • unload_filament_hemera.gcode
      • You have to use this file every time you want to unload filament from your Hemera. It is needed because the filament path is much shorter than Prusa extruder.
      • This step only needed because no custom firmware is available yet.
      • Insert the SD card in your printer with the Bear Hemera
      • In the menu of your printer select "Print from SD" and choose the file bear_hemera_config_mk*.gcode.
      • The printer might say it is an incomplete file but it is a wrong message, click to continue and print this file.
      • You can now delete the bear_hemera_config_mk*.gcode file from the SD card because it will not be used anymore.
      • From the printer's menu, disable the fan check with the menu Settings -> Fans check - On / Off
      • This is needed because the Hemera fan does not have a third wire to read the fan rotation
      • From the printer's menu, disable the filament sensor with the menu Settings -> Filament sensor - On / Off
      • As of today, the Bear Hemera does not have filament sensor, therefore it is better to disable it
      • From the printer's menu, run the PID calibration for your hotend with the menu Calibration -> PID calibration.
      • Raise the X axis to more than 30mm by pressing the LCD knob for longer than 3 seconds. Turn the knob to move up
      • Place a metallic object underneath the Pinda probe. The red light on the probe should turn off
      • If this test fails, do not attempt to print or use your printer. Carefully verify the wiring of your PINDA
      • The recent Prusa firmware allows you to check the value of the Pinda probe via the LCD menu Support -> Sensor info
      • From the printer's menu Settings -> Temperature -> Nozzle, set the nozzle temperature to 80°C
      • Return to the info screen (main screen)
      • Verify that the hotend fan is starting as soon as the temperature exceeds 50°C
      • Let the hotend cool down using the printer's menu Preheat -> Cooldown
      • If this test fails, do not attempt to print or use your printer. Carefully verify carefully the wiring of your hotend
      • From the printer's menu Settings -> Temperature -> Fan speed, set the fan speed to 130.
      • The nozzle fan (front fan) should now rotate at half speed.
      • If this test fails, do not attempt to print or use your printer. Carefully verify the wiring of your nozzle fan.
    1. 5. Software configuration, Configure PrusaSlicer: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 5. Software configuration, Configure PrusaSlicer: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Open PrusaSlicer, go to Printer Settings -> General -> Size and coordinates, then click on the Set ... button
      • On the Bed Shape window, set the X size to 240
      • And Y size to 205
    2. 5. Software configuration, Update PrusaSlicer profiles: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • In PrusaSlicer, go to Printer Settings -> Extruder 1 and reduce the retraction length to 0.5mm for PETG and 0.3mm for PLA
      • These values are only a starting point and you will need to adjust them later according to your tuning
      • The Hemera has a much shorter filament path and efficient cooling tha original Prusa extruder. If your retraction is too long you might clog the Hemera
      • This setting might be overridden by your filament settings, make sure to check them
      • With the BearMera, the bed calibration and self test will fail and should not be executed.
      • Bed calibration fails because of the geometry of the extruder. The Pinda and the nozzle have different positions.
      • The self test will fail because of the E3D fan which does not have the rotation sensor. It will also fail because of the bed calibration.
      • The bed calibration could potentially crash the nozzle which would damage the bed surface.
      • Calibrate your first layer with the printer's menu Calibration -> First layer calibration.
      • The first layer calibration will remove the following message that could appears when you power on the printer: "Distance between tip of the nozzle and the bed surface has not been set yet. Please follow the manual, chapter First steps, section First layer calibration.".
      • It is possible that with the weight of the Hemera, the X axis is moving down on one side when the printer is off for some time. If this happens, move the X up until it crashes as explained in this step. Note that his can also happen to stock Prusa printer (and so stock Prusa extruder)
      • After calibrating your first layer, we recommend to set your extrusion multiplier according to our guide here: Extrusion multiplier and filament diameter
      • Congratulations, you have finished to install and calibrate your BearMera extruder.
      • Happy printing :)
Greg Bear
crwdns2935283:011/04/26crwdne2935283:0
8,773 crwdns2915208:0crwdne2915208:0
crwdns2935297:035crwdne2935297:0
crwdns2936753:030crwdne2936753:0 28
crwdns2959996:0crwdne2959996:0 28
