y_axis_end_stop
Clip the y_axis_end_stop on the left smooth rod, at the front, as shown in the image
ptfe_collet_clip
Slide a PTFE tube into the collet. The length does not matter. The end needs to be cut flush.
Move up the collet while keeping the PTFE in place. Clip the ptfe_collet_clip to secure the collet.
Hot-tighten the Hemera nozzle to 3Nm at 285°C. Follow the official instructions of the E3D Hemera assembly guide here (step 18): https://e3d-online.dozuki.com/Guide/02+-...
Let the extruder cool down.
Place a sheet of paper on the heated bed. Manually lower the X axis until the Hemera nozzle is touching the paper.
Make sure the X axis is flat (you can slowly move the Hemera left and right while looking at the nozzle distance from the bed).
Loosen the PINDA locking screw and place an object of 1mm thickness under the Pinda (like the middle section of a zip tie).
Gently move the PINDA down until it is touching the zip tie.
Tighten the PINDA locking screw to secure it in place.
Plug in and turn on the printer
Using the screen menu, move the X axis up until it crashes into the Z tops. The stepper motors will skip, making a noise - this will not damage the motors
Using the screen menu, move the X axis down until the nozzle is approximately 10mm from the heated bed
If you have applied tension to the belt, unscrew the belt tensioner on x_end_idler until the belt is relaxed.
Loosen the screws that secure the trapezoidal nuts. This is to ensure that the Trapezoidal nuts 'self-centre' on the lead screws.
Make sure the trapezoidal nuts are moving freely.
Alternate between all 4 screws evenly while tightening (alternate between both sides during the process). Don't apply any lateral force on the trapezoidal nuts.
Loosen the two pulley set screws a little.
Align the pulley with the belt hole of the x_end_motor.
Tighten the set screws alternately.
Verify that the belt is not touching the x_end_motor.
Verify that the drive pulley is not touching the X motor.
Grip the X motor shaft with pliers to prevent it moving (grab the flat side of the shaft).
Tension the belt, by tightening the screws in the x_end_idler. Do this while trying to move the extruder to the left or right. The belt should stay straight and should not bow up and skip over the drive pulley teeth.
Adjust both M3x10 screws to have the x_end_idler parallel to the frame.
First image, top left: shows when the X axis is too short. In this case you need to tighten the two M3x10 screws.
First image, bottom left: shows when X axis is too long. In this case you need to unscrew the two M3x10 screws.
If you have difficulty to see if the x_end_idler is parallel to the frame you can use a thick ruler or a square like on the first image.
It might happen that with excess tension on the M3x10 screws, the Z smooth rods will start to be off center on the Z tops. In this case release tension on the M3x10 screws even if the x_end_idler is not totally parallel to the frame.
Download and install the Pano Tuner application (developed by Kaleloft LLC) on your smartphone. Android Google Play link. Apple Store link.
Turn off the printer (if your hotend is higher than 50°C, let the hotend cool down first until the hotend fan stops spinning)
Launch the Pano Tuner app and place your smartphone on the heated bed. Make sure there is no noise in the room that could disrupt the measure (like a ceiling fan).
Move the extruder to the middle of the X axis.
Pinch the lower belt to make it vibrate. Don't pinch too much as it might touch the carriage and produce a wrong frequency
Adjust the belt tension until you have a value around 90Hz. Between each measurements, move the extruder to full left and right and then center it again.
Verify the x_end_idler_tensioner is not sticking out of the x_end_idler.
As a starting point to adjust the extruder tension, E3D recommends to rotate the tensions screw until the white part is flushed with the front of the black part.
Congratulations you have finished this chapter :-)
Go to the next chapter: 5. Software configuration
