42" LG TV LED Strip Replacement Tutorial
crwdns2936621:0crwdne2936621:0
  1. 42" LG TV LED Strip Replacement Tutorial, LED Strip Replacement Tutorial: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws from the rear of the television, as well as the back cover.
  2. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws that connect the IR sensor to the mainboard to remove and detach it.
  3. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the ribbon wires from the buffer boards using the provided connectors.
  4. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the speakers from the mainboard by disconnecting them from it.
  5. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws on the assembly that are around the television.
  6. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws that hold the buffer board in place.
  7. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • For certain covers, you may need to pry the clips away from the bezel using a five-in-one tool or something similar to free the clips.
  8. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the buffer board covers from the board.
  9. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To get the buffer boards free, release the tabs on the boards.
  10. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bezel by flipping the television over.
  11. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip up the buffer boards and tape them to the panel using suction cups.
  12. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the panel off the television by lifting it evenly so that it does not break.
  13. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the panel frame.
  14. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tape the diffusion layers together at the corner to keep them aligned, then remove the layers of diffusion one by one, starting at the corner.
  15. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The reflector is held in place by two sets of tabs located on each side of it.
    Where can i buy these two sets of tabs?
    Vicente Delariarte - crwdns2934203:0crwdne2934203:0
  16. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pinch the smaller tabs through the chassis on the board side, using needle-nose pliers to get them tight.
  17. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Some of the smaller tabs may be placed under the boards; to reach at least one of the smaller tabs, you will need to remove the t-con board.
  18. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To release the bigger tabs, you will need to raise one side while sliding it.
  19. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the reflector sheet.
  20. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a five-in-one tool or something similar to disconnect the LED strips from the power cables and pry underneath the LED strips to lift them out of their mounting brackets on the chassis.
    Three LG strips for a 32" TV for example cost £25. It is possible to replace the failed led. My led's were in series, so if one fails open-circuit, all the led lamps in the strip go out. If one strip goes out so do the other strips). You have to be careful when testing them to ensure you don't put too much current through them or the led's will fail. You can buy special led testers and soldering stations, but they are not absolutely necessary. Pry off the plastic lens then modify a soldering iron (I used a 25W). I undid the screw on the soldering iron to remove the tip, and used the screw to attach a piece of metal with a flat area of size of the lens , bending the metal to get the best thermal contact with the iron. Then I lay the copper side of the strip opposite the failed led on the hot flat metal. It took about 5mins to melt the solder and slide the failed led away. The led must be replaced by a new led or one melted off another scrap strip. Re-glue on the lens. Used led's will have shorter life.
    Dave Empson - crwdns2934203:0crwdne2934203:0
  21. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Connect the new LED strips and make sure they are properly aligned on the chassis.
  22. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reconnect the LED strips to the power cable as they have been disconnected.
  23. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reconnect the reflector sheet and clips to the reflector frame.
  24. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the tape from the layers of diffusion and reinstall them.
  25. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reinstall the panel frame.
  26. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Adjust the panel's position and then remove the suction cups.
  27. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Release the buffer boards from the tape.
  28. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reinstall the bezel and tighten it down using the screws that run around the perimeter of the TV.
  29. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reinstall the buffer board covers on the board.
  30. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:030crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reconnect the t-con board and ribbon wires as they are disconnected.
  31. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reinstall the speakers and connect the wire to the mainboard.
  32. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:032crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reinstall the infrared sensor and tighten it to the chassis once more.
  33. 42" LG TV LED Strip Replacement Tutorial: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reinstall the back cover and put the screws back in place.
Removing and Reinstalling 4G LG TV LED Strips may sound tricky or complicated; however, after reading this tutorial for replacing the LED strips of LG 42inch LED TV, you can do it by yourself now! I hope you enjoy it. See you in the next tutorial.
crwdns2935229:018crwdne2935229:0
Rachel Burnham
crwdns2935283:007/16/21crwdne2935283:0
1,013 crwdns2915208:0crwdne2915208:0
Tv Lg 42lv3500 no se ve imagen , lo único que se ve son líneas de color verticales y luego van desapareciendo hasta quedar en negro , me podrían ayudar por favor
carlos fagundez - crwdns2934203:0crwdne2934203:0
No one ever shows how to get the wire adapters off the ends of the LED strips! Also, the spacers are very brittle, if you put a 5 in one under it, it will break. Take them off from behind and just push it in a little where the catch is and slide it gently on the face side.
Kevin York - crwdns2934203:0crwdne2934203:0
My Tv is blank (not showing picture but has a black light display instead of pictures) but still plays sound loud and clear. What could be the problem please? “LG 43" smart. Model 43uk6400plf. Firmware 5.50.15”
AfolabI Olakanmi - crwdns2934203:0crwdne2934203:0
Mine has the similar situation, no picture shown most the time and whenever picture is on, left half of the screen is flickering with white stripes (on and off) , I thought it might be the display controller's problem but not sure, will someone could guide a direction on how to fix it?
Sherman
Sherman Hsu - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 54
crwdns2936753:07crwdne2936753:0 297
crwdns2936753:030crwdne2936753:0 1,290
crwdns2942667:0crwdne2942667:0 60,294
