3DR Iris Plus Quadcopter Gimbal Removal Procedure
  1. 3DR Iris Plus Quadcopter Gimbal Removal Procedure, Gimbal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 3DR Iris Plus Quadcopter Gimbal Removal Procedure, Gimbal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 3DR Iris Plus Quadcopter Gimbal Removal Procedure, Gimbal: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If your drone is equipped with it, remove the video transmitter.
    • Disconnect all cables from the gimbal.
    • If your drone has neither the gimbal or video transmitter, you can skip this step.
  2. 3DR Iris Plus Quadcopter Gimbal Removal Procedure: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 3DR Iris Plus Quadcopter Gimbal Removal Procedure: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 16 mm screw attaching the gimbal mount to the body of the drone using the 3 mm Hex screwdriver/key.
  3. 3DR Iris Plus Quadcopter Gimbal Removal Procedure: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 3DR Iris Plus Quadcopter Gimbal Removal Procedure: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the drone 180 degrees.
    • Unscrew the other 16mm gimbal mount screw using the 3 mm Hex screwdriver/key.
  4. 3DR Iris Plus Quadcopter Gimbal Removal Procedure: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the gimbal mount from the body of the drone.
Evan Witulski
crwdns2935283:002/10/20crwdne2935283:0
349 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S7-G5, Regan Winter 2020 crwdns2935289:0Cal Poly, Team S7-G5, Regan Winter 2020crwdne2935289:0
CPSU-REGAN-W20S7G5
Where are the two wires connect to the gimbal one is a ground and the white wire connects to the power, but where?
James Reed - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 250
