32" Hisense LED TV Screen Replacement
crwdns2942287:0crwdne2942287:0Is the screen of your Hisense 32" TV having some issues and getting someone to replace it would cost a fortune? Try using this guide to fix it yourself!
crwdns2944105:0crwdne2944105:0
To begin, lay the TV screen-down on a smooth surface.
Unscrew the screws connecting both support legs to the TV.
To begin removing the back plate, find and remove all 18 screws indicated with the Phillips screwdriver.
Once all of the screws are removed, carefully pop off the back plate without damaging any of the connected wires.
Slide the power cord free from its metal framework.
After the power cord has been moved, remove the four screws keeping the housing in place. Once finished, remove the housing as well.
Remove the three silver screws connecting the circuit board to the rest of the TV that are circled in the picture using the Phillips screwdriver.
Remove the final silver screw, making sure to avoid disconnecting any of the wires that obscure it from view.
Remove all of the 18 screws connecting the front frame to the back of the TV with the Torx screwdriver.
Once the screws are all removed, slide the flat-head screwdriver into the small gap between the front and back plates. Use the screwdriver to pry the plates apart and lift the back plate up.
Completely separate the back from the front and flip the back section over so that the screen is now on top.
Find the cable pictured and detach the plastic film protecting the circuitry to which the cable is attached.
After detaching the plastic, detach the wire connecting the screen to the rest of the TV.
Next, the circuitry needs to be removed from the TV itself. Lift the screen circuitry free from the adhesive and then lift the screen free from the back section of the TV.
Now that the screen has been removed, take the new screen and attach its circuitry in the same place as the previous screen. After that, connect the cable from the rest of the TV to the screen's port and it should be good to go!
Hi i need a screen replacement cos mine is broken how can i get it am at limpopo mokopane town
Hi as i have sade i need hisense 32D screen replacement am at mokopane limpopo province how can I get it I sold apritiate if help
I need hisense 32 inch led screen. How much an in Ebonyi state of Nigeria
crwdns2935229:023crwdne2935229:0
crwdns2947412:026crwdne2947412:0
Where can I buy the replacement panel?
Could you please post the panel code of this tv model (32H3C)? I guess it could be the same my hisense tv need . It could help me to find the right spare part.
Thx
where can i buy Hisene LCD TV Screen pls?
where do I buy a replacement screen for 32inch hisence smart tv
How can I buy the 55inch screen. The straight TV not curve
Where can i buy 32” Hisense LED TV display
Model number - LEDN32D50
Where can i buy 47 inch Hisense led tv display
I want to fix my Hisense tv. 50NT.
can someone please help me, I accidentally pulled the three wires (red, White and black) out of the little plug that plugs into the screen itself, the plug has got 5 connectors
where i can buy screen replacement for 32inch hisence smart tv ?
I have a doble image in a hissense LED tv. What can I do for fix ir?
where to buy replacement parts and scree for hisense tv in south africa
Where can I buy a replacement tv screen panel (I cracked my tv screen). For a 32’ hisense model 32H4030F1
Where can I buy a replacement tv screen for hisense 32k370
Pls where can I buy Hisense led 50”screen for replacement
Where can I get 55” sceen Hisense,and how much that would cost me
Hi is this group still active?
Hello, kindly assist me in replacing my 32 inch screen
Help please I need a screen replacement for a 43 inch Roku tv hisense model 43r6e3
Where can I buy replacement screen for ledn32d30 hisense
Hi my 40nch Hisense in only display half of a screen the other half it blink in small stripes or just becomes blank in black.
What could be the problem or can I fix it
The 32” lcd tv the power is on ,red light on but the screen is no longer turning on
I have a 65inch Hisense tv, the LED is broken, where can I get a replacement?
I need a replacement for my 43inch Hicense Tv LED
Were can I by screen replacement 32 inch led tv hisense
