2009 Kia Sorento Door Handle Replacement
  1. 2009 Kia Sorento Door Handle Replacement, Door Handle: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2009 Kia Sorento Door Handle Replacement, Door Handle: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2009 Kia Sorento Door Handle Replacement, Door Handle: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before beginning this project be sure your window is rolled up or the glass will be in the way for later steps.
    • Before you can start removing the side panel, the speaker on the driver side door must be removed. To do this, simply squeeze and it will pop out. There is a little wire that connects the speaker to the car. To detach it there is a little button that can be pushed and it will come loose.
  2. 2009 Kia Sorento Door Handle Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2009 Kia Sorento Door Handle Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2009 Kia Sorento Door Handle Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the speaker is out, six screws need to be removed to allow the panel to detach from the door.
    • The first four are on opposite ends of the door. One pair is near the door hinge and another pair is located next to the seam.
  3. 2009 Kia Sorento Door Handle Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2009 Kia Sorento Door Handle Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a screwdriver to pry out the washers.
  4. 2009 Kia Sorento Door Handle Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2009 Kia Sorento Door Handle Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2009 Kia Sorento Door Handle Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screw securing the door handle.
    • Remove the door handle.
  5. 2009 Kia Sorento Door Handle Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2009 Kia Sorento Door Handle Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the final screw next to the lock and window buttons in a little hole.
  6. 2009 Kia Sorento Door Handle Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool or any other prying tool to remove the panel.
  7. 2009 Kia Sorento Door Handle Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the wires that control the locks, windows, and lights in the car door.
  8. 2009 Kia Sorento Door Handle Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2009 Kia Sorento Door Handle Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold down the little button and pull the wire away from the car.
  9. 2009 Kia Sorento Door Handle Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2009 Kia Sorento Door Handle Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2009 Kia Sorento Door Handle Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Detach the two white blocks of wires.
  10. 2009 Kia Sorento Door Handle Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2009 Kia Sorento Door Handle Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2009 Kia Sorento Door Handle Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After all the wires are detached and the door panel is set to the side, pull back the plastic seal to gain access to the bolts.
    • You don't need to completely remove it, just enough to fit your hand inside to unscrew the bolts.
  11. 2009 Kia Sorento Door Handle Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2009 Kia Sorento Door Handle Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are two bolts behind the plastic you just pulled back and one to the outer side of the car door behind a little plastic cover.
  12. 2009 Kia Sorento Door Handle Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2009 Kia Sorento Door Handle Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a socket wrench with a 10mm attachment to loosen the bolts. To remove the bolts on the inside of the door, just loosen the bolts with the socket wrench and then use your hands to remove it completely.
  13. 2009 Kia Sorento Door Handle Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2009 Kia Sorento Door Handle Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2009 Kia Sorento Door Handle Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the door handle from the vehicle.
  14. 2009 Kia Sorento Door Handle Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2009 Kia Sorento Door Handle Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2009 Kia Sorento Door Handle Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the semi-circle piece away from the metal rod and remove the metal rod.
  15. 2009 Kia Sorento Door Handle Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2009 Kia Sorento Door Handle Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2009 Kia Sorento Door Handle Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now that the old door handle is fully detached from the car you can now put in your replacement part.
Jack Wilson
crwdns2935283:010/29/19crwdne2935283:0
489 crwdns2915208:0crwdne2915208:0
University of Memphis, Team S1-G5, Willis Fall 2019 crwdns2935289:0University of Memphis, Team S1-G5, Willis Fall 2019crwdne2935289:0
UM-WILLIS-F19S1G5
I got up to "remove the white blocks (electrical) from the door panel". I couldn't get them out. Any suggestions?
Richard Waller - crwdns2934203:0crwdne2934203:0
I'm about to do this 2009 Kia Sorento LX both driver and passenger front handle replacement next weekend. I hope yours went well, wish me luck!!
MoniB -
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 55
crwdns2942667:0crwdne2942667:0 4,307
