2007 Toyota 4Runner Headlight Bulb Replacement
  1. 2007 Toyota 4Runner Headlight Bulb Replacement, Headlight Bulb: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2007 Toyota 4Runner Headlight Bulb Replacement, Headlight Bulb: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Raise the hood of your 4Runner.
    • Find the back of the headlight assembly.
    • Move the battery or air filter housing, depending on what side you're replacing, to access the bulb more easily.
    • If you're working on the battery side you’ll have to remove the battery. Remember to disconnect the negative terminal first and handle the battery carefully to avoid any electrical hazards.
    • Find the negative terminal (usually black cable and a “–” sign). Turn the nut of the negative terminal clamp loose with a 10mm wrench or socket. Twist and lift the cable end away from the battery post. Keep moving it aside so it cannot accidentally spring back into contact with the terminal.
    • Usually the positive terminal is red and has a ‘+’. Lift the clamp off the battery post and repeat the same procedure with loosening the nut, as above. When you remove the cable end, make sure it does not touch the battery.
    • Loosen and remove the hold-down bracket and set it aside.
    • If the battery has built in handles, use them. If not, grab the battery from its sides. Just lift it straight up and out of the engine bay. Put it on a safe, level spot.
  2. 2007 Toyota 4Runner Headlight Bulb Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2007 Toyota 4Runner Headlight Bulb Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To release the bulb, press the tab on the connector then remove it.
    • Do not tug on the wires directly.
  3. 2007 Toyota 4Runner Headlight Bulb Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2007 Toyota 4Runner Headlight Bulb Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the bulb socket, turn it counterclockwise out of the headlight housing.
    • Pull the old bulb out of the socket carefully.
  4. 2007 Toyota 4Runner Headlight Bulb Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2007 Toyota 4Runner Headlight Bulb Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be cautious not to touch the glass portion of the bulb, as oil from your skin can shorten its lifespan.
    • Put the new bulb into the socket and turn it clockwise until it’s tight.
  5. 2007 Toyota 4Runner Headlight Bulb Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2007 Toyota 4Runner Headlight Bulb Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure that the wiring connector clicks back in.
    • Now you're done! Turn on your car and turn on the blinker!
Kenny Nguyen
crwdns2935283:010/21/24crwdne2935283:0
136 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 3-30, Harris Fall 2024 crwdns2935289:0CSU Los Angeles, Team 3-30, Harris Fall 2024crwdne2935289:0
CSULA-HARRIS-F24S3G30
crwdns2942667:0crwdne2942667:0 252
