2004 Toyota Sienna Sliding Door Motor Replacement
crwdns2936621:0crwdne2936621:0
  1. 2004 Toyota Sienna Sliding Door Motor Replacement, Sliding Door Motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • First, test both sliding doors to identify the problem with the driver's side door
    • source.
  2. 2004 Toyota Sienna Sliding Door Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the second-row seat to access the door panel
    • source.
  3. 2004 Toyota Sienna Sliding Door Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two Phillips screws holding the door panel in place
    • source.
  4. 2004 Toyota Sienna Sliding Door Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the door panel by lifting it out and disconnect the power window
    • source.
  5. 2004 Toyota Sienna Sliding Door Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Close the door and observe the actuator motor on the working passenger side door for comparison
    • source.
  6. 2004 Toyota Sienna Sliding Door Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the driver's side door, test the voltage to confirm it's an issue with the actuator motor and not an electrical problem
    • source.
  7. 2004 Toyota Sienna Sliding Door Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Order a replacement actuator motor (Part #s in the video) and wait for its arrival
    • source.
  8. 2004 Toyota Sienna Sliding Door Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the window regulator by lowering the window and accessing the bolts through the portholes
    • source.
  9. 2004 Toyota Sienna Sliding Door Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the actuator motor by grinding off the stripped Phillips screws with a Dremel tool or using vice grips
    • source.
  10. 2004 Toyota Sienna Sliding Door Motor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the actuator motor with the new part, using socket screws from wall sockets or light switches if necessary
    • source.
  11. 2004 Toyota Sienna Sliding Door Motor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reassemble the window regulator and test the window function
    • source.
  12. 2004 Toyota Sienna Sliding Door Motor Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Test the sliding door in manual mode and then in power mode
    • source.
eCuration
crwdns2935283:005/19/17crwdne2935283:0
449 094 crwdns2915208:0crwdne2915208:0
crwdns2935297:0251crwdne2935297:0
Great instructions! I was able to fix sliding door.
However, the window doesn’t scroll up all the way and it wiggles if you pull on it.
What did did I do wrong? Any suggestions are appreciated.
Nara Lim - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 2,626
