(AAA) Cleaning battery leakage (Maxxum 5000/7000)
  1. (AAA) Cleaning battery leakage (Maxxum 5000/7000), An example of a "borderline" cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 (AAA) Cleaning battery leakage (Maxxum 5000/7000), An example of a "borderline" cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 (AAA) Cleaning battery leakage (Maxxum 5000/7000), An example of a "borderline" cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This is WHY you clean the corrosion - not polish it off. This cover was properly treated, but it still required a wire brush cleanup as well!!!
    • Severe terminal damage (wire brush needed)
    • Had to use sandpaper to fix
  2. (AAA) Cleaning battery leakage (Maxxum 5000/7000), Unscrew the cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Unscrew the cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Unscrew the cover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the battery cover from the body. Remove the bad batteries.
  3. (AAA) Cleaning battery leakage (Maxxum 5000/7000), Remove the battery retention clip: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Remove the battery retention clip: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Remove the battery retention clip: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To thoroughly clean the AAA cover, you must disassemble it. You will not be able to fully clean it assembled.
    • Stick a screwdriver or pry tool in the side with one pin. DO NOT pry on the side with 2; it can break the second pin.
    • LIft up on the clip and remove it. This can be safely cleaned in a vinegar bath.
  4. (AAA) Cleaning battery leakage (Maxxum 5000/7000), Optional: Pre-clean the cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Optional: Pre-clean the cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Optional: Pre-clean the cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This step will REDUCE the nickel-plating damage, not prevent it.
    • Before cleaning the corossion, use a chemical like denatured alcohol and a disposable toothbrush to clean some of the corrosion. Once this is done, rinse and dry the cover.
  5. (AAA) Cleaning battery leakage (Maxxum 5000/7000), Battery corrosion neutralization: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Battery corrosion neutralization: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If there is any stubborn alkaline on the screw plate, sand the affected tab down until you have a good connection and STOP. The tabs are VERY THIN.
    • With the battery holder disassembled, clean the clip by soaking it in vinegar.
    • If affected, clean the tabs on the screw cover with a toothbrush or Q-Tip.
  6. (AAA) Cleaning battery leakage (Maxxum 5000/7000), Reassemble the cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Reassemble the cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 (AAA) Cleaning battery leakage (Maxxum 5000/7000), Reassemble the cover: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the side with 2 pins in FIRST, then let it rest.
    • Push down to lock the cover in place. Note: You may need to push the plastic on the screw plate back with a pry tool.
    • Put it in the closed position, and check if it opens correctly and accepts batteries.
  7. (AAA) Cleaning battery leakage (Maxxum 5000/7000), Test the camera: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Install fresh batteries and take a few test shots.
    • If it works, shoot on with the old cover if desired and convert later :-).
    • If the camera is still dead, try a known good cover, or buy a used one with no existing corrosion, and re-assess the camera.
Nick
crwdns2935283:011/10/09crwdne2935283:0
94.403 crwdns2915208:0crwdne2915208:0
crwdns2935297:059crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0327crwdne2931471:0
crwdns2935297:01.690crwdne2935297:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 599
