Battery
crwdns2933315:02crwdne2933315:0 crwdns2934263:04crwdne2934263:0 |
What is charging error 5 |
crwdns2933313:01crwdne2933313:0 crwdns2934263:00crwdne2934263:0 |
How can I change the language? |
Goes in circle error 2 clean brushes |
- iRobot Roomba 800 and 900 Series Brush and HEPA Filter Maintenance Set - IR800SET244
- iRobot Roomba 800, 900 Side Brush Module
- iRobot Roomba 500, 600, 700, 800, 900, E5, E6, E7, J7, J7+ Front Caster Wheel Assembly
- iRobot Roomba 500, 600, 700, 800, 900, E5, E6, E7, J7, J7+ Rubber Tire
- iRobot Roomba 500, 600, 700, 800, 900, I3, I4, I6, I6+, I7, I7+, I8, E5, E6, E7 Edge-Sweeping Brush
Troubleshooting
For information on troubleshooting this product, check out our troubleshooting page here.
Background
The iRobot Roomba 805 is a domestic robot available to the public as an alternative to manual vacuum cleaners, while not giving up the performance. Its size and mobility allows it to clean most homes with ease, being able to fit under tables and get into most corners, It also has a spinning brush on the side of the circular design to help reach against walls and flat edges that a circle configuration alone would not be able to reach, however it is limited to a single floor of the home. Although limited by stairs and different levels of flooring, the Roomba can clean carpet, hardwood, and tile autonomously. This device comes with a docking station and a compatible app for most smart phones and tablets that allows users to run the product even when they are not home.
Identification
Identified by model number: 805
Technical Specifications
Roomba
- Weight: 8.38 lbs.
- Width 13.9 in.
- Height 3.62 in.
- 60 minute run time
- 33 watt battery
Docking Station
- 120 minute charge time
Sources: Smart Robot Reviews
