crwdns2935069:03crwdne2935069:0
crwdns2933307:0crwdne2933307:0
crwdns2961394:0crwdne2961394:0
PST2 400
Background and Identification
The Wacker Pump model PST2 400 (model number 0620435) is a single-phase electric submersible utility pump. It can handle up to 0.4-inch solids for dewatering of excavations, flooded basements, utility vaults, swimming pools, lakes, manholes, or wherever there is unwanted water. The pump includes a 2-inch motor and an oil-filled cavity that keeps the motor lubricated. Built-in thermal protection prevents damage to the motor due to impeller blockage.
The PST2 400 model includes silicon carbide-face double mechanical seals that run in the oil-filled motor cavity and allow seal lubrication, cooling, and overall motor protection. The pump includes a 20-foot electrical cord and has maximum discharge flow of 3180 gallons per hour. It uses a 0.5-horsepower motor to move water with some submerged solids. PST models feature shaft-mounted agitators which are designed to suspend solids when pumping water containing sand and debris.
The PST2 400 model includes aluminum housing and a threaded male outlet connection. It includes a yellow motor casing and a black float. A black and silver handle is positioned at the top of the pump’s body for carrying and positioning the machine. A black sticker with white font is included on the top of the pump’s yellow body that includes identification information like the machine’s model number.
Technical Specifications
Dimensions:
  • Product Depth (in.): 7.3
  • Product Height (in.): 10.1
  • Product Width (in.): 13
Details:
  • Amperage (amps): 5.4
  • Cord Length (ft.): 20
  • Discharge Flow @ 0 ft. (gallons/hour): 3780
  • Discharge Flow @ 0 ft. (gallons/min): 63
  • Discharge Flow @ 10 ft. (gallons/hour): 3360
  • Discharge Flow @ 10 ft. (gallons/min): 56
  • Head Pressure (ft.): 39
  • Housing Material: Aluminum
  • Maximum Discharge Flow (gallons/hour): 3180
  • Maximum Horsepower (hp): 0.5
  • Maximum Pressure (psi): 52.8
  • Maximum Working Temperature (F): 111
  • Minimum working temperature (F): 40
  • Outlet Connection: Threaded male
  • Power Type Required: AC
  • Product Weight (lb.): 25lb
  • Pump Switch Type: Switchless
  • Vertical Lift (ft.): 39
  • Voltage: 110v
Additional Information
Pompe PST2 400 — Notice d'emploi
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:07crwdne2936753:0 37
crwdns2936753:030crwdne2936753:0 150
crwdns2959996:0crwdne2959996:0 10,005
