crwdns2933307:0crwdne2933307:0
Hardware Specifications
CPU
CPU Model:Intel Celeron J4025
CPU Architecture: 64-bit
CPU Frequency: 2-core 2.0 (base) / 2.9 (burst) GHz
has Hardware Encryption Engine (AES-NI)
Memory
System Memory: 2 GB DDR4 non-ECC
Total Memory Slots: 1
Maximum Memory Capacity: 6 GB (2 GB + 4 GB)
Storage
Drive Bays: 2
Compatible Drive Type: 3.5" SATA HDD, 2.5" SATA HDD and 2.5" SATA SSD
Maximum Single Volume Size: 108 TB
Hot swappable Drive
External Ports
RJ-45 1GbE LAN Port: 2 (with Link Aggregation / Failover support)
USB 3.0 Port: 2
USB / SD Copy
File System
Internal Drives: Btrfs, EXT4
External Drives: Btrfs, EXT4, EXT3, FAT, NTFS, HFS, exFAT
Appearance
Size (Height x Width x Depth): 165 mm x 108 mm x 232.2 mm
Weight: 1.30 kg
System Fan: 92 mm x 92 mm x 1 pcs
Noise Level: 19.3 dB(A)
AC Input Power Voltage: 100 V to 240 V AC / 50/60 Hz, single phase
Power Consumption: Power Supply Unit / Adapter 60 W
  • 14.69 W (Access)
  • 4.41 W (HDD Hibernation)
Source : synology.com
Additional Information
Synology NAS DS220+ Hardware Installation Guide
Synology DiskStation DS220+ Datasheet
Sandra Hiller
crwdns2935283:010/17/16crwdne2935283:0
37,368 crwdns2915208:0crwdne2915208:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:072,955crwdne2935297:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 115
crwdns2959996:0crwdne2959996:0 3,506
