SYNOLOGY DS220 +: a complete disassembly in rules
  1. SYNOLOGY DS220 +: a complete disassembly in rules, Presentation : the different faces of the case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SYNOLOGY DS220 +: a complete disassembly in rules, Presentation : the different faces of the case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Here are the different interesting sides of the case: front (disk bay, LEDs), rear (connectors and fans).
    • power button
    • 2 x RJ45 Gb ports
    • Disk and system activity LEDs
    • Kensington security slot (K-lock)
    • 1 x power supply port
    • 2 x USB 3 ports (1 front and 1 back)
    • 1 x reset button
  2. SYNOLOGY DS220 +: a complete disassembly in rules, Disassembly : disk cage removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • nothing complicated ... remove the cage from the SIN while pressing the push button
  3. SYNOLOGY DS220 +: a complete disassembly in rules, Backplane and memoy access: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS220 +: a complete disassembly in rules, Backplane and memoy access: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS220 +: a complete disassembly in rules, Backplane and memoy access: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 2 x SATA port
    • Only the empty memory slot is accessible.
    • Evolution since v2018: internal memory (2 GB) is soldered on board.
  4. SYNOLOGY DS220 +: a complete disassembly in rules, Case : removing the cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS220 +: a complete disassembly in rules, Case : removing the cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS220 +: a complete disassembly in rules, Case : removing the cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a screwdriver (flat tool) to unlock the two plastic lugs.
    • These are two locking notches (on the front, left side) to be "unlocked" or "unlatched".
    • Be careful not to bend the metal bar.
    • then slide the two parts of the shell parallel to each other, as shown in the pictures.
    • then separate the two parts from each other perpendicularly.
    • the removal of the rear screws (fan, plate) is not mandatory ...
  5. SYNOLOGY DS220 +: a complete disassembly in rules, Teardown : internal parts: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS220 +: a complete disassembly in rules, Teardown : internal parts: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS220 +: a complete disassembly in rules, Teardown : internal parts: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • orange : internal SATA ports
    • yellow : fan connector
    • blue : fan
    • green : free memory slot
  6. SYNOLOGY DS220 +: a complete disassembly in rules, Teardown: spacer holding cage and case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SYNOLOGY DS220 +: a complete disassembly in rules, Teardown: spacer holding cage and case: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • simply unscrew the screw to remove the spacer.
    • You will notice the guides for positioning the spacer.
  7. SYNOLOGY DS220 +: a complete disassembly in rules, Teardown: spacer holding fan: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • same as above ... unscrew the screw to remove the plastic spacer
    • you will also notice the markers ...
  8. SYNOLOGY DS220 +: a complete disassembly in rules, Teardown: motherboard removal 1/2: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SYNOLOGY DS220 +: a complete disassembly in rules, Teardown: motherboard removal 1/2: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • to remove the motherboard from the case, unscrew the 4 screws as follows ...
    • There are 4 x screws to fix the metal support of the motherboard. 4 x screws to fix the motherboard to the metal support. And finally 4 x screws to fix the disk bay cage to the metal support of the motherboard. Pay attention!
  9. SYNOLOGY DS220 +: a complete disassembly in rules, Teardown: motherboard removal 2/2: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • once the screws are removed, pull the front panel (at the USB port) slightly outwards ...
    • This allows the connectors to pass through.
    • then lift up the motherboard with the disk cage.
  10. SYNOLOGY DS220 +: a complete disassembly in rules, Teardown: removal of the disk bay: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SYNOLOGY DS220 +: a complete disassembly in rules, Teardown: removal of the disk bay: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • remove the yellow marked screws (x4)
    • no specific photographs ... nothing very complex!
    • This step is not mandatory to access the motherboard
  11. SYNOLOGY DS220 +: a complete disassembly in rules, Teardown: removal of the mobo's metal support: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the yellow marked screws (x4)
  12. SYNOLOGY DS220 +: a complete disassembly in rules, Internal parts : case, motherboard: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS220 +: a complete disassembly in rules, Internal parts : case, motherboard: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SYNOLOGY DS220 +: a complete disassembly in rules, Internal parts : case, motherboard: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 1 - motherboard on the processor side
    • 2 - motherboard memory side
    • 3 - empty case
  13. SYNOLOGY DS220 +: a complete disassembly in rules, Thanks !: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Photograph showing one of the phases of dismantling the NAS.
To reassemble your device, follow the instructions in reverse order.
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Sébastien
crwdns2935283:012/14/15crwdne2935283:0
4,498 crwdns2915208:0crwdne2915208:0
AEM (ANIMA EX MACHINA) crwdns2935289:0AEM (ANIMA EX MACHINA)crwdne2935289:0
Business
Bonjour,
Savez-vous s'il est possible d'acheter la Carte Mère de ce model?
Merci d'avance pour votre réponse
Léo - crwdns2934203:0crwdne2934203:0
Bonjour,
N'oubliez pas qu'en mettant les disques dans une baie plus récente,
le NAS va migrer le système avec les données.
De fait, sauf pour une application très particulière,
il ne semble pas y avoir un intérêt économique à racheter une carte mère de 2020
Sinon il faudrait l'acheter / la trouver très peu cher …
D'ailleurs, pas certain qu'elle soit encore produite (j'en doute fortement même).
Cela dit, demandez à Synology directement (leur site n'en parle pas : https://www.synology.com/fr-fr/products/...)
Ils ont leur réseau de distributeur et depuis que maintenant ils proposent de la maintenance c'est possible qu'il le reste du stock (ca reste un modèle grand public donc pas certain).
Sinon il reste l'occasion … avec les risques associés …
Bref pas si simple …
Sébastien -
crwdns2936753:07crwdne2936753:0 35
crwdns2936753:030crwdne2936753:0 197
crwdns2942667:0crwdne2942667:0 7,684
