Repairing Samsung WF361BVBEWR ND Error Code
crwdns2933313:01crwdne2933313:0 crwdns2934263:00crwdne2934263:0 |
Why is my machine leaking when the washer is filling? |
How to unlock washer door |
crwdns2933315:02crwdne2933315:0 crwdns2934263:00crwdne2934263:0 |
Why does the machine fill up above normal level and then give a nf err |
Why is my washer making loud noise? |
Background and Identification
The Samsung WF361BVBEWR is a front-load washing machine with a total capacity of 3.6 cubic feet. The machine features eight wash cycles and has a maximum spin speed of 1100 revolutions per minute (RPM). It includes a 900 Watt internal water heater, eight wash options (normal, heavy-duty, permanent press, sanitize, delicates and hand wash, wool, quick wash, and rinse + spin), and four temperature setting options. The Samsung WF361BVBEWR washing machine can be paired with an electric dryer (model DV361EWBEWR) or a gas dryer (model DV361GWBEWR). The washing machine includes Samsung’s Purecycle option, a delay start up to 19 hours, an extra rinse option, five soil levels, and a sound on/off button.
A washing machine (laundry machine, clothes washer, or washer) is a machine to wash laundries, such as clothing and sheets. The term is mostly applied only to machines that use water as opposed to dry cleaning (which uses alternative cleaning fluids, and is performed by specialist businesses) or ultrasonic cleaners. Washing entails immersing, dipping, rubbing, or scrubbing in water usually accompanied by detergent, or bleach.
The simplest machines may simply agitate clothes in water while switched on; automatic machines may fill, empty, wash, spin, and heat in a cycle. Most washing machines remove substantial amounts of water from the laundry at the end of a wash cycle but do not completely dry it.
Technical Specifications
Features:
- Total Capacity (cu. ft.): 3.6
- VRT™: Yes
- Purecycle™: Yes
- Wash Cycles: 8
- Spin Speeds: 1100 RPM
- Internal Water Heater: 900 W
- Options: 6
- Temperature Setting Options: 4
- Drum Light: Yes
Dimensions:
- Product Dimensions: 27" x 38 3/8" x 31 1/2"
Color:
- Color: White
- Display Color (LED: )Red
- Display Type: LED
Energy:
- IMEF: 3.12
- IWF: 3.01 WCF
- Energy Guide Label: Energy Guide LabelPDF download
Wash Cycles:
- Normal: Yes
- Heavy Duty: Yes
- Permanent Press: Yes
- Sanitize: Yes
- Delicates and Hand Wash: Yes
- Wool: Yes
- Quick Wash: Yes
- Rinse + Spin: Yes
Options:
- Purecycle™: Yes
- Delay Start: 19 Hrs.
- Extra Rinse: Yes
- Soil Levels: 5
- Sound On / Off Button: Yes
Temperature Settings:
- Hot / Cold: Yes
- Warm / Warm: Yes
- Warm / Cold: Yes
- Cold / Cold: Yes
Spin Speeds:
- High: Yes
- Medium: Yes
- Low: Yes
- No Spin: Yes
- Maximum Spin Speed: 1100 RPM
Soil Levels:
- Heavy: Yes
- Normal: Yes
- Light: Yes
Warranty:
- One (1) Year All Parts and Labor: Yes
- Two (2) Years Control Board: Yes
- Three (3) Years Stainless Steel Tub: Yes
- Ten (10) Years Motor: Yes
Matching Dryer:
- Electric Dryer: DV361EWBEWR
- Gas Dryer: DV361GWBEWR
Power:
- Energy Consumption: 94 kWh/Yr
Quiet Performance:
- VRT™ Vibration Reduction: Yes
Weight:
- Product Weight (lb.): 176.2 lb.
- Shipping Weight: 185 lb.
Additional Information
- Samsung WF361BVBEWR Washing Machine Product Page
- Versus: Samsung WF361BVBEWR Washing Machine Review
- Samsung WF361BVBEWR Washing Machine Replacement Parts
Samsung WF361BVB/WF363BTB/WF365BTB Drum Washing Machine Service Manual
