Safety First! Before you begin, remember that safety is paramount. Always unplug your washing machine before attempting any repairs or diagnostics. This precaution is crucial to prevent electric shock or damage to your appliance.
Understanding Your Washing Machine: This guide covers various problems, from water inlet problems to drying challenges or unexpected leaks. We’ve broken down each problem into three key sections:
  1. Problem: Identifies the specific issue you're experiencing.
  2. Why It Happens: Provides a brief explanation of potential causes.
  3. How to Fix: Offers step-by-step solutions to resolve the issue.
Ready to Solve the Issue? With this guide in hand, you're well-equipped to handle washing machine issues with ease. Let’s dive in and get your washing machine running smoothly again!
4C, 1 4C, nF, or 4E — Water Supply Error
Why It Happens?
The washer isn't getting enough water or the water level isn't changing as expected.
How to Fix
  1. Ensure your water supply is turned on and the hose isn't kinked.
  2. Restart the washer by turning it off and on.
5C, 1 5C, nd, 5E, SE, or SC — Water Drain Error
Why It Happens?
The washer is having trouble draining water.
How to Fix
  1. Check for blockages in the drain hose and filter.
  2. Restart your washer to reset the system.
OC, OE, 1OC, 0C, 0E, or 1 0C — Overflow Error
Why It Happens?
Too much water in the washer.
How to Fix
  1. Reduce the load size and ensure the detergent amount is correct.
  2. Reset the washer by turning it off and on.
Ub, UE, Ur, U6, dc*, 1 Ub, or 1U6 — Unbalance Error
Why It Happens?
The laundry load is uneven or too small.
How to Fix
  1. Adjust the load to balance it, or add more items.
  2. Reset the washer to clear the error.
HC, HE, HE1, Hr, or 1 HC — Water Heater Error
Why It Happens?
The water temperature is changing unexpectedly.
How to Fix
  1. Check the water heater settings
1C, 1E, LE, LC, LC1, 1 1C, or 1 LC — Water Level or Leakage Error
Why It Happens?
An issue with the water level sensor, or there is a leakage in the washer.
4C2, 4E2, CE, 14C2, or nF1 — Abnormal Water Temperature Error
Why It Happens?
The water temperature is not suitable for the selected cycle.
tC1 - Thermistor Error
Why It Happens?
A problem with the temperature sensor.
3C, 3E, E3, or 1 3C - Motor Restriction Error
Why It Happens?
The motor is having difficulty moving. Check your manual to determine whether code 3E is a voltage error or motor error.
FC, 9C1, 9C2, PF, 3E, 2E, 9E1, 9E2, UC, 19C1, or 19C2 - Voltage Error
Why It Happens?
The voltage supply is invalid. Check your manual to determine whether code 3E is a voltage error or motor error.
Matt Zieminski
crwdns2935283:002/23/15crwdne2935283:0
50,412 crwdns2915208:0crwdne2915208:0
crwdns2935297:028crwdne2935297:0
Staff
crwdns2935297:072,931crwdne2935297:0
crwdns2944067:06crwdne2944067:0
Mi lavadora samnsung marca el error 3E2, como puedo saber si es el sensor hall o la tarjeta?
Gustavo - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Bonjour, lave linge Samsung buble eco, le Tambour ne tourne pas et affiche ce code erreur : 3E2. Merci pour votre aide
Madrane - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hola Buenas Estamos buscando el
Diagrama eléctrico de una lavadora automatica Samsung
WD7122CKC un error en la puerta y no funciona
Cindy Rod Zuñ - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Lavadora samsung inverter no centrifuga hace un sonido por el motor
Tomas jauregui arbieto - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 19
crwdns2936753:07crwdne2936753:0 120
crwdns2936753:030crwdne2936753:0 465
crwdns2959996:0crwdne2959996:0 8,455
