Battery
crwdns2933313:01crwdne2933313:0 crwdns2934263:03crwdne2934263:0 |
Broken power button, unable to turn onw |
Kg lock permanent bypass |
crwdns2933313:01crwdne2933313:0 crwdns2934263:01crwdne2934263:0 |
How do I flash firmware? |
It vibrates while it not on what is the cause |
crwdns2935065:0crwdne2935065:0
Background
The Samsung Galaxy XCover line of smartphones are a line of phones designed to be used in more rugged workplace environments. These phones are produced by Samsung, a South Korean tech conglomerate based in Seoul, but with global influence in the tech industry. The Galaxy XCover Pro was released in January of 2020 and was designed with a more durable frame and protective shell intended for use in more rugged environments.
The device uses a Nano-SIM card and holds 64 GB of space, with 4 gigs of RAM. It also has a microSDXC slot accessed by the removeable back cover. The smartphone is MIL-STD-810G compliant, meaning it has met military grade standards for durability and environmental resistance.
As the first in the line of XCover Pro phones, the device houses an IPS LCD display with an Octa-core CPU, as well as a dual camera housing a 25 MP, f/1.7, 26mm (wide) lens and 8 MP, f/2.2, 123˚ (ultrawide), 1/4.0", 1.12µm lens.
Identification
The Samsung Galaxy Pro phone can be identified by the textured back cover that can be removed for easy access to the replaceable battery and microSDXC and SIM2 card slots. For another identifier, the red-lined "Push-to-Talk" button can be found on the left side (Screen facing you) of the smartphone. The model number can be found by removing the back cover and pulling out the battery of the smartphone, printed on a sticker in the battery bay.
Identified model numbers beginning with SM-G715F, SM-G715U, or SM-G715W.
Technical Specifications
- Body
- 159.9 x 76.7 x 10 mm (6.30 x 3.02 x .39 in)
- 219 g (7.69 oz)
- Nano-SIM
- Nano-SIM + Nano-SIM
- MIL-STD-810G compliant
- Display
- IPS LCD
- 6.3 in, 97.4 square cm
- Resolution: 1080 x 2340 pixels in a 19.5:9 ratio
- Corning Gorilla Glass 5
- Software
- Android 10, can upgrade to Android 13, One UI 5
- Exynos 9611 (10 nm)
- CPU: Octa-core (4x2.3 GHz Cortex-A73 & 4x1.7 GHz Cortex-A53)
- GPU: Mali-G72 MP3
- microSDXC
- 64 GB storage, 4GB RAM
- Back Camera
- Dual:
- 25 MP, f/1.7, 26mm (wide), PDAF
- 8 MP, f/2.2, 123˚ (ultrawide), 1/4.0", 1.12µm
- Dual-LED flash, HDR, panorama
- Video: 1080p@30fps
- Dual:
- Front Camera
- 13 MP, f/2.0, (wide), 1/3.1", 1.12µm
- HDR
- Video: 1080@30fps
- Audio
- Loudspeaker
- 3.5mm headphone jack
- Internet/Communication
- Wi-Fi 802.11, dual-band, Wi-Fi Direct
- Bluetooth: 5.0, A2DP, LE
- GPS, GLONASS, GALILEO, BDS
- NFC included
- FM radio
- USB Type-C 2.0
- Sensors
- Fingerprint, accelerometer, gyro, proximity, compass ANT+
- Battery
- Li-Po 4050 mAh, removable
- 15w wired charging
Additional Information
Samsung Galaxy XCover Pro official product page
Frequently Asked Questions about the Samsung Galaxy XCover Pro
Samsung Galaxy XCover Pro Specifications
HotHardware Review: Samsung Galaxy XCover Pro
