Remember when you needed to take a whole separate device with you when you wanted to take a quality picture? Maybe you don't, but smartphones have made that largely a thing of the past. Except when the camera can't take a decent picture because everything comes out blurry. Don't miss the opportunity for a perfect shot because your camera isn't up to the job.
The Basics
Before undertaking any of the more time consuming solutions below, these are a few fundamentals to get you started.
  • Restart your phone. It’s amazing what a simple power off and on can clear up.
  • While attempting to take a photo, tap the image preview on screen. This will prompt the camera to focus on the area you touched.
  • Ensure the camera in use is the one you intend. The image on screen may be for the front facing camera rather than the rear one, or vice versa.
  • Force the camera app closed. It may just be hung on something; forcing the app to restart could resolve this.
  • If you’re using a third party app, check the iPhone camera app to see if the image is sharper. Other apps with camera functionality built in will not always take full advantage of the hardware and do not make use of Apple's software tuning.
Camera is Obstructed
Solution: Clean camera and remove accessories
In order for your camera to take pictures, it needs a clear line of sight to the image you're trying to capture. It's easy to miss that something is getting in the way of your camera, especially if the something is your finger.
  • Clean the glass lens over your cameras with a microfiber cloth. Debris on the glass could be causing blurry pictures or blacking out the camera altogether.
  • If your issue is with the front facing camera, verify your screen protector is not in the way.
  • Check for glass damage to the camera area. The camera itself may be perfectly fine, but the glass over the camera sensor can crack, affecting image quality. This glass can be replaced, in many cases, even without replacing the rest of the back glass.
Incorrect Camera Settings
Solution: Correct settings
Now that we live in a world where a Galaxy phone could have two, three, or four camera sensors, finding where the issue lies can be a bit more complex.
  • Verify you are using the intended camera by hitting the button to flip between front facing and rear cameras.
  • Check which mode you are using. If you are not using a mode intended for your environment, the image may show up incorrectly (i.e. using Portrait mode when you're not taking a portrait).
Buggy Software
Any software which contains errors can cause the camera to work improperly. Before opening your phone to take parts out, ensure it's not a simple software fluke.
  1. Try a different app with built in camera function.
  2. If the camera works in other functions, open the recent apps menu and close the problematic app.
  3. Reopen the affected app and try to recreate the issue. If it reoccurs, check the App Store for updates and install them. Uninstall and reinstall the app if no updates are present.
  4. To rule out software entirely, be sure you have a current backup, and reset your phone to factory settings.
Damaged Optical Image Stabilization
Solution: Replace the camera
Most rear facing Galaxy phone cameras make use of optical image stabilization technology. As you snap a photo, it uses readings from the gyroscope to attempt to compensate for camera movement so your images don’t come out blurry. Repeat exposure to strong vibration or a heavy drop can cause this mechanism to malfunction.
  • Damage typically causes the camera to appear as though it is constantly shaking. You may even be able to hear or see it moving around in the housing.
  • The best fix for this is a [[ crwdns2944616:0crwdne2944616:0 ]]replacement. The movement of the camera sensor is controlled by small electromagnets and circuitry inside the camera. Repairing those is difficult and time consuming.
crwdns2944686:0crwdne2944686:0
Avoid solutions which involve affixing a strong magnet to your camera assembly. It may resolve the issue, but risks wreaking havoc on the rest of your phone if the magnet doesn't stay put.
Faulty Camera
This can also be caused by any number of other camera related faults. Issues with only one of the many camera sensors can cause issues with others, or the whole photo-taking system.
  • Isolate which camera is faulty by checking the front facing camera or various camera modes. Use other apps to see if they are also affected.
  • Replace the offending camera or camera assembly with a [[ crwdns2944616:0crwdne2944616:0 ]].
crwdns2916044:0crwdne2916044:0
Even if your phone has multiple cameras and only one failed, you may need to replace the whole assembly. Individual camera are more difficult to source, depending on the model.
Liquid Damage
Despite the common conception that many Galaxy phones are waterproof, that is pure marketing myth. Even with increasing levels of resistance, water will find a way.
  • Check your camera lens for signs of condensation. It tends to collect over the glass protecting the camera sensor.
  • Condensation in the camera may indicate more serious liquid ingress to your phone. Skip the rice and use the iPhone Liquid Damage Guide for your best chance at minimizing any the damage.
  • The camera, or other components may need to be replaced as a result.
Alisha C
crwdns2935283:012/04/20crwdne2935283:0
43,605 crwdns2915208:0crwdne2915208:0
LGBTQ Technicians crwdns2935289:0LGBTQ Technicianscrwdne2935289:0
Community
crwdns2931471:071crwdne2931471:0
crwdns2935297:0852crwdne2935297:0
crwdns2944067:06crwdne2944067:0
Comment on peut faire pour rendre le camera's pi belle
Velor - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Comment on peut faire pour rendre plus belle Dire moi
Eu qr q resolvar o problema da camera do meu cll
Samuel Reis - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Échec appareil photo Samsung 20
Fatia - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Mon appareil photo Samsung 20s je reçois échec de l appareil photo
crwdns2936751:024crwdne2936751:0 46
crwdns2936753:07crwdne2936753:0 299
crwdns2936753:030crwdne2936753:0 1,161
crwdns2959996:0crwdne2959996:0 19,953
