crwdns2933313:01crwdne2933313:0 crwdns2934263:00crwdne2934263:0 |
The screen displays a circle outline spinning. The washer won't fill. |
crwdns2933313:01crwdne2933313:0 crwdns2934263:01crwdne2934263:0 |
Machine will power up after a restart but will not start a cycle |
Background: The Samsung WF210ANWXAA is a front-load washing machine designed for household laundry. The user manual included with it provides information about setting up the washer, using its wash cycles, adding detergent and softener, cleaning the machine, maintaining the door lock and debris filter, and identifying troubleshooting and informational error codes. The manual also includes product specifications and safety information for handling. Samsung's official troubleshooting information explains that washing machine problems may involve water-supply errors, leaks, drainage problems, door errors, overflow, and many more error codes that may appear while operating the machine. This information can help users directly identify the issue affecting their washer and provide them with the needed information to resolve the issue.
Identification: This Samsung washer is identified in Samsung's documentation as the WF210ANWXAA model. The device can be identified by its Samsung branding on the top left corner, front-opening loading door, control panel, automatic detergent and softener dispenser, and separate compartments for detergent, fabric softener, and bleach. The control panel includes wash-cycle controls and features including child lock, spin only, clothing color black, and water level. This model could also be recognized by the codes alerted to the users when an error occurs. Such as door unlocked, unbalanced load, and other errors.
Technical Specifications:
- Model: Samsung WF210ANW/XAA
- Type: Front-loading washer
- Height: 38 inches (96.5 cm)
- Width: 27 inches (68.6 cm)
- Depth: 31.1 inches (80 cm)
- Depth with door open 90 degrees: 50.8 inches (129 cm)
- Weight: 183 pounds (83 kg)
- Water pressure: 20–116 psi (137–800 kPa)
- Power supply: 120 volts
- Heater rating: 900 watts
- Spin speed: 1,100 revolutions per minute
- Power consumption—washing: 140 watts
- Power consumption—washing and heating: 960 watts
- Power consumption—spin: 430 watts
- Power consumption—drain: 80 watts
- Additional Information:
