Background
The Royal Heat RS-100 was manufactured in Taiwan in 1989. It works by flowing electric current through a resistive coil and converting it into heat energy. The heating elements inside the heater are called the coils which contain many layers of metal (a conductor) wound around a core.
The Royal Heat RS-100 functions as a fan heater. It transfers heat from the device to the surrounding area by using an electric fan.
Identification
To differentiate the Royal Heat RS-100 from other space heaters, look for the following features. On the front, the RS-100 has four rectangular resistors with a metal net cover, a dial-switch with three positions (Heat-Off-Fan), and a dial to adjust the power. On the back, a removable filter hides the fan inside. On the bottom of the heater, you will find the identification plate and it contains the model number (RS-100), power input and output, and the serial number.
Specifications
Model: RS-100
Release Date: 07/1989
Power Source Required: Standard 120v 2-prong outlet
Color: Black
Power consumption: adjustable up to 1500W
Voltage rating: 120 V (60Hz)
Output: Up to 5200 BTU
Dimensions: 6.5 L x 5 W x 7.5'' H
Unit weight: 8 lbs
Additional Information
Electric Heater Repair
Honeywell Heater Troubleshooting
Heater's Common Problems (section 7.52)
Wikipedia: Electric heating
Basic Soldering Instructions
How to solder instructions with video
Jorge Revelo
crwdns2935283:010/14/13crwdne2935283:0
224 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 11-35, Amido Fall 2013 crwdns2935289:0Cal Poly, Team 11-35, Amido Fall 2013crwdne2935289:0
CPSU-AMIDO-F13S11G35
crwdns2935297:084crwdne2935297:0
crwdns2936753:030crwdne2936753:0 71
crwdns2959996:0crwdne2959996:0 5,446
