crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
Background and Identification
The Revo RM215-OR1 was introduced in 2011 and is intended to be used with a security system. While it is designed for this purpose and has ports with this in mind, the monitor uses a standard VGA input and can also be used on a PC if you purchase one of these monitors with this intention in mind. It can also be wall mounted, which is accomplished with a VESA mount. The monitor requires a VESA 100x100 mount, if it is wall mounted.
This monitor is typically bundled with a security system set, but was available separately. Most monitors that are found independent of the corresponding security system likely came from a bundle that included this monitor.
To verify this is the monitor you have, check the back of the monitor. The label should say MODEL NO: RM215-OR1.
Ports and Specifications
Note: The Audio Out port may not function on a PC.
Panel specifications
  • Panel size: 21.5"
  • Resolution: 1366x768
  • Panel type: TN
  • Backlight: LED with high voltage driver
Input options
  • VGA
  • Audio In
  • Audio Out
Nick
crwdns2935283:011/10/09crwdne2935283:0
106,311 crwdns2915208:0crwdne2915208:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0335crwdne2931471:0
crwdns2935297:08,260crwdne2935297:0
crwdns2936753:030crwdne2936753:0 50
crwdns2942667:0crwdne2942667:0 1,329
