crwdns2911028:0crwdne2911028:0
crwdns2862668:0crwdne2862668:0
This wiki is missing a device image. Help improve this page by uploading one!
crwdns2934263:02crwdne2934263:0
crwdns2934263:01crwdne2934263:0
Background and Identification
The Respironics Millennium 10 is a ten-liter oxygen concentration machine. The machine produced a flow rate of up to 10 liters per minute. Oxygen concentrators are medical devices that filter surrounding air and compress it in order to produce purified medical grade oxygen. The device can then administer the oxygen to the patient through a pulse-dose or continuous stream delivery system. Oxygen concentrators are typically used to treat patients with breathing disorders or with a lower concentration of oxygen in their blood than normal.
The Respironics Millennium 10 includes alarm indicators for high system pressure, low system pressure, power failure, low oxygen levels, and no oxygen flow. The machine’s electronic wires and tubing are protected by plastic tubing. A twin-head compressor is used to send more airflow through the machine’s sieve beds. The Millennium 10 model is sold with and without an oxygen purity indicator. The Oxygen Percentage Indicator (OPI) measures oxygen output ultrasonically as a purity indication.
The Respironics Millennium 10 can be identified by the name “Millennium” printed in white font on a black area in the machine’s upper right-hand corner. The name “Respironics” is printed in capital letters underneath the name “Millennium.” Underneath this identifying information, the machine includes several LED alarm indicators that alert the user to any problems with the device.
Technical Specifications
Dimensions: 27" x 19" x 13" in
Flow Rate: Up to 10 LPM in 1-liter increments l/min
Electrical Requirements: 120V/60Hz (+/- 10%)
Warranty: One-year standard/Optional two years (excludes compressor)/Optional two-year compressor
Oxygen Percentage Indicator: Green Light greater than 82%/Yellow Light between 70-82%/Red Light less than 70%
Weight: 53 +/- 0.5 lb
Oxygen Concentration: 92 +/– 4% @ 8-10 LPM; 94 +/– 2% @ 3-7 LPM; 92 +/– 4% @ 1-2 LPM
Storage/transport temperature: -30 to 160 °F
Operating temperature: 55 to 90 °F
Storage/transport humidity: Up to 95%, non-condensing %
Operating pressure: 10 to 30 PSI
Alarm indicators: High system pressure/Low system pressure/Power failure/Low oxygen level (OPI model available on the M10605 model only)/No oxygen flow
Additional Information
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 64
crwdns2959996:0crwdne2959996:0 4,119
