crwdns2935069:03crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
Background and Identification
This gas-powered pressure washer is manufactured by Mi-T-M, an equipment manufacturer that sells a variety of machines for industrial, commercial, and residential use. Their products include pressure washers, portable heaters, generators, air compressors, and other equipment. Pressure washing, sometimes called power washing, is a method of spraying high-pressure water or detergent mixture to blast off dirt, paint, or other materials from a surface.
This pressure washer is a medium to heavy-duty machine that can be used for commercial or industrial cleaning work such as construction or farm equipment, paint removal, and other applications. It has several notable features. First, there are three nozzle options, which create a spray pattern at 0°, 15° or 25° as needed. This allows the user to adjust the width of the spray for detailed, accurate cleaning or better area coverage as needed. Second, this pressure washer is equipped with a vibration isolation plate that absorbs noise and vibration while the machine is running, making it easier to use.
Note: The manufacturer, Mi-T-M, refers to this model with the number CA-4004-1MGH. However, the Home Depot rental page refers to it as CA-4004-HDHB. Whether this is because Mi-T-M changed the model numbering or because Home Depot uses a unique numbering system is unclear. Either way, the machine can be recognized by the 4000 PSI label on the plate attached to the handle, and by the Mi-T-M logo.
Technical Specifications
  • Engine: Honda GX390
  • Engine Displacement: 389cc
  • Net Weight: 125.00 lbs.
  • Shipping Weight: 175.00 lbs.
  • Length: 42.50 in.
  • Width: 23.50 in.
  • Height: 24.50 in.
  • Lance: 48 in.
  • PSI: 4000
  • GPM: 4.0
  • Pump: General
  • Mi-T-M No.: 3-0350
  • Unloader: Mi-T-M, Adjustable Pressure
Additional Information
Home Depot Rental Page
Mi-T-M Product Page
Mi-T-M CA Series Operation Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936751:024crwdne2936751:0 19
crwdns2936753:07crwdne2936753:0 116
crwdns2936753:030crwdne2936753:0 486
crwdns2959996:0crwdne2959996:0 35,818
