Feet
crwdns2933307:0crwdne2933307:0 crwdns2934263:03crwdne2934263:0 |
Why is my scroll wheel "over-scrolling" in the opposite direction? |
crwdns2933307:0crwdne2933307:0 crwdns2934263:00crwdne2934263:0 |
Left mouse button dent |
Logitech G Pro Wireless battery connector extremely stuck |
crwdns2933307:0crwdne2933307:0 crwdns2934263:01crwdne2934263:0 |
G pro wireless right click problem |
M-R0070
Additional Parts
Logitech Parts
Background
The Logitech G Pro Wireless gaming mouse was designed for esports professionals. It features Logitech’s Lightspeed technology wireless technology and HERO (High Efficiency Rated Optical) 25K sensor. The mouse is lightweight at 80 grams. It has a primary, secondary, and middle click. The G Pro Wireless mouse also has four removable side buttons.
Identification
The Logitech G Pro Wireless has a left and right click buttons on top, a scroll wheel near the front, and forward and backward buttons on the left side. It looks very similar to the G Pro X Superlight mouse, except that it has "Pro Wireless" etched into the bottom. The Logitech logo is printed near the rear of the top of the mouse, and is also etched into the circular door on the bottom of the mouse. The bottom of the mouse is ridged. By removing the circular door (which is secured with two small magnets), you can find the model number M‑R0070 as well as the part and serial numbers.
There are five feet on the bottom of the mouse—a long one on the top edge, a circular one around the bottom sensor, and three smaller ones near the bottom.
The mouse comes in two colors:
- Black : 910-005270
- Shroud : 910-005974
Technical Specifications
Physical Specifications
- Height: 4.92 in (125.0 mm)
- Width: 2.5 in (63.5 mm)
- Depth: 1.57 in (40.0 mm)
- Weight: 2.82 oz (80 g)
- Cable length: 70.86 in (1.80 m)
Tracking
- Sensor: Hero 25K
- Resolution: 100 – 25,600 DPI
- Zero smoothing/acceleration/filtering
- Max. acceleration: >40G
- Max. speed: >400 IPS
Responsiveness
- USB data format: 16 bits/axis
- USB report rate: 1000 Hz (1 ms)
- Wireless technology: Lightspeed Wireless
- Microprocessor: 32-bit ARM
Durability
- PTFE Feet: > 250 kilometers
Battery Life
- Default lighting: 48 hours
- No lighting: 60 hours
Other features
- Powerplay compatible
- Onboard memory: 5 profiles
- Lightsync RGB: 1 zone
- Mechanical Button Tensioning System
Requirements
- Windows® 7 or later
- macOS® 10.11 or later
- Chrome OS™
- USB port
- Internet access for Logitech G HUB (optional)
Part Number
