Logitech G PRO Wireless Feet Replacement
  1. Logitech G PRO Wireless Feet Replacement, Turn off the PRO Wireless: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G PRO Wireless Feet Replacement, Turn off the PRO Wireless: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G PRO Wireless Feet Replacement, Turn off the PRO Wireless: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Shift the power switch down to turn off your mouse (when the PRO Wireless label is oriented right-side up).
    • The color behind the switch should be red when the mouse is switched off.
  2. Logitech G PRO Wireless Feet Replacement, Apply heat to the upper mouse foot: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you plan to reuse the mouse feet, you'll need to apply heat to loosen the adhesive and remove the feet with minimal bending.
    • Heat an iOpener and apply it to the upper mouse foot for one minute.
    • A hair dryer or heat gun may also be used, but be careful not to overheat the mouse—the internal battery is susceptible to heat damage. If you use a hair dryer or heat gun, set it to the lowest temperature setting and apply heat for 10 seconds.
  3. Logitech G PRO Wireless Feet Replacement, Insert the spudger under the upper mouse foot: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G PRO Wireless Feet Replacement, Insert the spudger under the upper mouse foot: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of a spudger under the upper mouse foot.
    • Each mouse foot has a gap in its recess that you can use to insert the spudger.
    • The mouse feet are made of two layers. Make sure you insert the spudger under the bottom layer to completely remove the foot.
  4. Logitech G PRO Wireless Feet Replacement, Remove the upper mouse foot: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G PRO Wireless Feet Replacement, Remove the upper mouse foot: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G PRO Wireless Feet Replacement, Remove the upper mouse foot: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the spudger under the length of the upper mouse foot to cut through the adhesive and detach it from the mouse.
    • Work slowly to avoid bending the mouse foot. If the adhesive becomes difficult to cut through, remove the spudger and apply more heat.
  5. Logitech G PRO Wireless Feet Replacement, Apply heat to the lower mouse feet: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply the iOpener to the lower mouse feet for one minute.
    • Alternatively, use a hair dryer or heat gun to apply heat for ten seconds.
  6. Logitech G PRO Wireless Feet Replacement, Remove the lower mouse feet: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G PRO Wireless Feet Replacement, Remove the lower mouse feet: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of a spudger under the left lower mouse foot.
  7. Logitech G PRO Wireless Feet Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G PRO Wireless Feet Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G PRO Wireless Feet Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the spudger under the length of the left lower mouse foot to cut through the adhesive and detach it from the mouse.
  8. Logitech G PRO Wireless Feet Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G PRO Wireless Feet Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the procedure to remove the two remaining lower mouse feet.
  9. Logitech G PRO Wireless Feet Replacement, Adhesive information: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you're going to install replacement mouse feet or apply new adhesive, use the flat edge of a spudger to remove the remaining adhesive in the mouse foot recesses.
    • If there's any adhesive residue left, use isopropyl alcohol and a microfiber cloth to remove it. Allow the surface to completely dry.
    • During reassembly, follow this guide if you are using a pre-cut adhesive card to secure the mouse feet.
Kyle Smith
crwdns2935283:002/01/21crwdne2935283:0
48,094 crwdns2915208:0crwdne2915208:0
crwdns2935297:0123crwdne2935297:0
crwdns2936753:07crwdne2936753:0 35
crwdns2936753:030crwdne2936753:0 214
crwdns2942667:0crwdne2942667:0 13,008
