Battery
crwdns2933315:02crwdne2933315:0 crwdns2934263:03crwdne2934263:0 |
Magnetic Casing Causing the Unit to Not Stay On |
Background:
Amazon introduced the first Kindle in 2007, after beginning development in 2004 under the codename 'Fiona.'. The Kindle, meaning, ‘to light a fire,’ has continued to be produced in cheaper and slimmer models. The first iteration, the Amazon Kindle, cost $399, which is equivalent to about $612 in 2025. The current models in the Generation 12 line, such as the Kindle Paperwhite 12th Gen, were priced starting at $160.
The Kindle system was designed to be used as an E-Ink E-Reader, meaning it's meant to simulate reading a real book on a virtual device while reducing eye strain and readability in the sunlight. Beyond this, Kindle devices also support Wikipedia and dictionary tools that allow users to look up words within their texts, a translation feature to read foreign texts, and a Review function through Goodreads. The Kindle Paperwhite 12th Gen was released on October 16th, 2024. It had multiple versions, available with or without ads, and a ‘Signature Edition’ with a larger storage capacity.
All models are available in black, raspberry, and jade body colors, and have official case options for each.
Identification:
To identify the Amazon Kindle Paperwhite 12th Gen (2024), check for its 7-inch display, which is larger than the 6-inch screen found on previous Paperwhite models. It has thin bezels and features an adjustable warm light, a feature not available in older versions like the 10th Gen (2018). The charging port is USB-C, whereas earlier models use Micro-USB. It also has a flush-front design and an IPX8 waterproof rating.
To confirm the exact model, go to Settings>Device Info, where it is labeled as Kindle Paperwhite (12th Generation) in Amazon’s software updates. If the device is unresponsive, the model number SA568B can be found on the back of your device.
Technical Specifications:
Display
Amazon’s 7” Paperwhite display technology with built-in light, 300 ppi, optimized font technology, 16-level grayscale.
Size
5” x 7” x 0.3” (127.6 x 176.7 x 7.8 mm)
Weight
7.4 oz (211g). Actual size and weight may vary by configuration and manufacturing process.
System Requirements
None; fully wireless and does not require a computer to download content.
On-Device Storage
16 GB; holds thousands of books.
Cloud Storage
Free cloud storage for all Amazon content.
Battery Life
A single charge lasts up to twelve (12) weeks, based on a half hour of reading per day with wireless off and the light setting at 13. Battery life may vary depending on use. Audible audiobook streaming over Bluetooth will reduce battery life.
Charge Time
Fully charges in less than 2.5 hours with a 9W USB power adapter.
Wi-Fi Connectivity
Supports 2.4 GHz and 5.0 GHz networks with up support for WEP, WPA, WPA2, WPA3, and OWE security using password authentication or Wi-Fi Protected Setup (WPS). Does not support connecting to ad-hoc (or peer-to-peer) Wi-Fi networks.
Waterproofing
IPX8-rated waterproofing, tested to withstand immersion in 2 meters of freshwater for up to 60 minutes.
Words cited:
Amazon - Kindle Paperwhite 12th gen
