crwdns2934263:02crwdne2934263:0
Background
The InFocus LP540 is a digital projector that has video and computer inputs. It can be easily connected, used, and maintained. The Interactive Display, located on top of the projector, provides constant feedback on the device's status. Additionally, the projector has a cable-free digital projection when connected with the InFocus LiteShow wireless adapter. The projector comes with built-in speakers as its audio source.
Identification
You can identify your InFocus LP540 by the model and serial numbers printed on the bottom of the projector. It is a square shape and made of gray and silver plastic. The InFocus logo is stamped on top in a silver background and printed on the front of the projector in gray on a silver background. It has a grille-like vent on the side of the device to keep the projector cool.
Specifications
Display
  • 40 inches - 300 inches diagonal size
  • 4:3, 16:9 aspect ratio
  • XGA (1024 x 768) resolution
  • SXGA+ (1400 x 1050) resolution input (max)
  • 400:1 contrast ratio
  • 3 LCD display technology
  • Front, ceiling, and rear projector placement
  • 480p, 576p, 720p, Full NTSC, PAL, SECAM, 1080i, 1080p/24 video compatibility
  • VGA (640x480), XGA (1024x768), SVGA (800x600), SXGA (1280x1024), SXGA+ (1400x1050) data compatibility
Audio
  • 2W (2 x 1 Watt) speakers
Connectivity (Input/Output)
  • 1 RJ45
  • VGA Monitor Output
  • 1 RS232
  • 1 Stereo 3.5mm Mini Jack Input
  • M1, S-video, and Composite (RCA) connections
  • 2 Stereo RCA Input
Lamp Specifications
  • 1700 lumens brightness (high)
  • 2000 lamp hours (high)
  • 170 lamp wattage (high)
Lens/Optical Specifications
  • Digital Keystone Correction (Vert.): +/- 25°
  • H-Sync Max (kHz): 110
  • H-Sync Min (kHz): 16
  • Lens Zoom Ratio: 1.2:1
  • Optional Lenses: No
  • Projection Distance (max, feet): 32.8
  • Projection Distance (min, feet): 5
  • V-Sync Max (Hz): 85
  • V-Sync Min (Hz): 50
Physical Attributes
  • No HDCP Compatibility
  • (10.3 x 4.1) Product Dimension (W x D x H)(inches)
  • 7.5 pounds Product Weight
  • (10 x 15 x 14) Shipping Dimensions (W x D x H) (inches)
  • 15 pounds Shipping Weight
Additional Information
DUKANE ImagePro 8758/8772 User's Guide
ASK Proxima C160 and C180 Projectors General and Functional Specifications
InFocus Work Big LP540 — folleto del proyector
InFocus LP540 Meeting Room Projector Brochure
Nishant Mattu
crwdns2935283:001/24/14crwdne2935283:0
19 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Cal Poly, Team 13-17, Regan Winter 2014 crwdns2935289:0Cal Poly, Team 13-17, Regan Winter 2014crwdne2935289:0
CPSU-REGAN-W14S13G17
crwdns2931471:06crwdne2931471:0
crwdns2959996:0crwdne2959996:0 5,068
