Movemement Mechanism
crwdns2933313:01crwdne2933313:0 crwdns2934263:00crwdne2934263:0 |
My wall clock not run ,I have changed his bettry. |
crwdns2933313:01crwdne2933313:0 crwdns2934263:01crwdne2934263:0 |
It has stopped ticking |
FirsTime wall clocks are battery-powered quartz clocks, usually running on a single AA battery. Common problems are a clock that stops or only runs intermittently, which is often caused by a weak battery, corroded or loose battery contacts, or a worn quartz movement. Cleaning the contacts and fitting a fresh battery will fix many cases; if the clock still does not run reliably, the quartz movement can usually be replaced as a unit.
