FirsTime Wall Clock Movemement Mechanism Replacement
  1. FirsTime Wall Clock Movemement Mechanism  Replacement, Movemement Mechanism: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 FirsTime Wall Clock Movemement Mechanism  Replacement, Movemement Mechanism: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove all four screws on the back of the clock.
  2. FirsTime Wall Clock Movemement Mechanism  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once screws are removed, simply remove the glass lens covering the display of the clock by lifting it with your hands.
  3. FirsTime Wall Clock Movemement Mechanism  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 FirsTime Wall Clock Movemement Mechanism  Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the display face up.
    • Use needle nose pliers to pull off the 'second' hand.
  4. FirsTime Wall Clock Movemement Mechanism  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 FirsTime Wall Clock Movemement Mechanism  Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use needle nose pliers to remove the 'minute' hand.
    • Then use needle nose pliers to remove the 'hour' hand.
  5. FirsTime Wall Clock Movemement Mechanism  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all hands are removed, use a 7/16-inch wrench to unscrew, in counter clockwise direction, the threaded nut in the center of the clock.
    • Removing the threaded nut is what allows the movement mechanism to be removed from the clock.
  6. FirsTime Wall Clock Movemement Mechanism  Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 FirsTime Wall Clock Movemement Mechanism  Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the washer underneath the nut with your fingers.
  7. FirsTime Wall Clock Movemement Mechanism  Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now you may remove the display of the clock from your malfunctioning movement mechanism.
crwdns2935229:025crwdne2935229:0
Samid Rehan
crwdns2935283:002/20/19crwdne2935283:0
723 crwdns2915208:0crwdne2915208:0
University of Memphis, Team S2-G2, Baddour Spring 2019 crwdns2935289:0University of Memphis, Team S2-G2, Baddour Spring 2019crwdne2935289:0
UM-BADDOUR-S19S2G2
crwdns2947412:07crwdne2947412:0
Is there a you tube showing these steps?
Patricia Ander - crwdns2934203:0crwdne2934203:0
Thank you! there was one tricky thing—the parts I got in the order did not match what I took off, so I had to reconfigure it a bit per new instructions that came with the parts. But I figured it out! Thank you for this instruction.
Leslie Benitez - crwdns2934203:0crwdne2934203:0
there seem to be 2 projections keeping the back & glass together.
I don't want to break them.
Marcia Kaminski - crwdns2934203:0crwdne2934203:0
Where can I buy the exact clock?
Barb - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 36
crwdns2936753:030crwdne2936753:0 186
crwdns2942667:0crwdne2942667:0 12,551
