crwdns2935069:06crwdne2935069:0
580.3263
Background
The Craftsman Generator 580.326300, manufactured by GOLDSTAR for Sears, is a single-cylinder, air-cooled engine designed to meet low emissions standards. The engine, which is overhead valve (OHV), is certified by the California Air Resources Board to meet emissions standards for 250 hours. The generator is rated for a maximum power of 6300 watts (6.3 kW) and a surge power of 9100 watts (9.1 kW). It produces a rated AC voltage of 120/240 volts and a rated frequency of 60 HZ at 3600 rpm.
The generator's engine specifications include a rated horsepower of 11 at 3600 rpm, a bore of 3.3 in. (83.81 mm), and a stroke of 2.438 in. (61.67 mm). The engine has a displacement of 20.85 in. (342 cc) and uses a Champion RC12YC spark plug or its equivalent. The generator has a fuel capacity of 7 U.S. gallons and uses different oil types depending on the temperature, with SAE 30 recommended for temperatures above 40° F and SAE 5W-30 or 10W-30 for temperatures below 40° F.
Technical Specifications
  • Engine Horsepower: 11 at 3600 rpm
  • Engine Bore: 3.3 in. (83.81 mm)
  • Engine Stroke: 2.438 in. (61.67 mm)
  • Engine Displacement: 20.85 in. (342 cc)
  • Fuel Capacity: 7 U.S. gallons
  • Oil Type: SAE 30 (Above 40°F); SAE 5W-30 or 10W-30 (Below 40°F)
  • Maximum Power: 6300 Watts (6.3 kW)
  • Surge Power: 9100 Watts (9.1 kW)
  • AC Voltage: 120/240 Volts
  • Maximum AC Current at 240 Volts: 26.3 Amperes
  • Maximum AC Current at 120 Volts: 52.5 Amperes
  • Frequency: 60 Hz at 3600 rpm
  • Phase: Single Phase
  • Unit Weight: 198 lbs.
Warranty
The Craftsman Generator 580.326300 comes with a limited warranty. The warranty covers the alternator and engine of the portable generator for a period of 2 years for consumer use and 1 year for commercial use. However, it is important to note that the warranty is not transferable and applies only to generators driven by the Sears warranted engine. During the warranty period, Sears will repair or replace any defective part under normal use and service. It is the responsibility of the purchaser to bear all transportation costs, including the return to the factory if necessary, and prepaid by the purchaser. The warranty does not cover normal maintenance and service or any parts that have been subjected to improper installation or alteration, misuse, negligence, accident, overloading, overspeeding, improper maintenance, repair, or storage. To claim the warranty, the purchaser should contact a Sears authorized warranty service facility, as service can only be performed by them. Evidence of the original purchase date must be presented at the time of requesting warranty service.
Craftsman 580.326300 Owners Manual
crwdns2935291:0crwdne2935291:0
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 56
crwdns2959996:0crwdne2959996:0 1,693
