Battery
crwdns2933307:0crwdne2933307:0 crwdns2934263:00crwdne2934263:0 |
Why is my right ear not working? |
crwdns2935065:0crwdne2935065:0
Background
The ATH-M20xBT headphones are the new and improved version of the old ATH-M20x wired headphones. The new design is upgraded to include Bluetooth compatibility and better low-frequency performance. The M20xBT allows you to connect to two different devices at a time when needed. The ATH-M20xBT headphones can run for 60 hours on a full charge. When the battery runs out, you can rapid charge them for 10 minutes to get 3 hours of playtime for your headphones. The headphones come with an included 1.2 mm cable if you would like to have a wired connection.
Identification
Unsure if you have the correct device? These are some easy ways to check if this page matches your device. The easiest way to identify if you have Audio-Technica’s ATH-M20xBT is to check on the right side of the headband for the model number, which is printed there as well as on the ear muffs. To make sure you have the Audio-Technica ATH-M20xBT’s and not just the ATH-M20’s, check to see if your headphones have a detachable 3.5 mm cable (you should have got a detachable 3.5 mm cable and a USB-C cable with the device). If so, you have the Bluetooth version of the model rather than the plain ATH-M20’s. Unlike some other Audio-Technica models, the ATH-M20’s earmuffs will not swivel. You can also always check to see if your headphone’s match the specs given below; you can check your device’s specs on the original packaging.
Technical Specifications
Headphones
- Type: Closed-back dynamic
- Driver Diameter: 40 mm
- Frequency Response Range: 5 to 32,000 Hz
- Impedance: 36 ohms
- Weight: ~216 g
- Power Supply: DC 3.7 V lithium polymer battery
- Charging Time: 4 hours
- Operating Time: 60 hours
Bluetooth
- Bluetooth Version: 5.0
- Operating Range: 10 m (33 ft)
Additional Information
Audio-Technica ATH-M20xBT Overview
Audio-Technica ATH-M20xBT Support Page
